Buying used vs new help......
/ Buying used vs new help...... #1
Eastcoastlaxin
De
Buying
I am currently in the market for a new or used tractor. I have the option of a new Kioti ck35 without the tier 4 compliance or a JD 3120 with 500 hours. The new kioti is 20800 and the JD is 14500. I have had a JD in the past and know how they are built and regret selling it. I have been looking at the Kioti ck35 and it meets my needs. The problem I am having deciding is the warranty... Would you go new for the 4 yr warranty or take the used for $6200 less and no warranty? All comments and input are greatly appreciated. By the way the JD is 8 yrs old.... Thanks in advance!!
/ Buying used vs new help...... #2
:welcome: To TBN. No experience with either machine, but $6200 is a lot of dough to me and goes a long way toward repairs if needed on the JD. How do the tires look? Tires are high as _ell.
/ Buying used vs new help...... #3
Have the used tractors been kept inside or outside?
The new Kioti is outdoors and the used JD is kept in a garage. The tires look hardly worn on the JD but there is a 6 hp difference between the two, JD being less. I mis read the numbers earlier and didn't realize I was comparing two tractors of different HP.. All be it is only 6 hp difference. JD is a 29 hp... Kioti is a 35 hp... Going to be doing a lot of reseeding, small FEL work, maybe eventually a Harley rake.
/ Buying used vs new help...... #5
I'd rather have the machine that's 8 years newer, has a warranty, doesn't already have 500 hours on it, and has more power.
/ Buying used vs new help...... #6
I went new because the interest rates buying used would be the same as the monthly payment of a new one. Also, the dealer's service has lots to do with it for me. Buying used, is this from an individual or a dealer?
Also, lots of things can happen to good tractors in the first 4 years that a warranty can cover. First oil change I found a bolt sticking to the magnetic plug. I documented it and made my dealer put in writing that I discovered it during the warranty. As it turned out.............nothing bad has come of it. But it could have. You never know until you commit. Then again, $6200 can buy a lot of after market warranty for 4 years.
hugs, Brandi
/ Buying used vs new help...... #7
hugs, Brandi
That's right, Brandi. My kids are always declining store or dealer warranties and finding better ones on line. I just am too old fashioned to figure out how they do it. From some of the comments here, I wouldn't be too excited about new machine warranties anyhow. Add in the extra hassle of that tier 4 stuff and well.... As far as financing, I'm assuming the OP has cash for the machine. If not, that is something else to consider. If the Deere is clean and handles well, I'd do that, but try to haggle a little first.
/ Buying used vs new help...... #8
I think they are called extended warranties. I get infor all the time to extend the warranty on my
Ram 3500 dually. I bought it used with no warranty.
hugs, Brandi
/ Buying used vs new help...... #9
I've bought both new and used. Felt better with new and a factory warranty. One of my kids bought a warranty and discovered it wasn't worth very much because of exclusions and deductibles.
I also do things a little differently with financing. I don't. The first two tractors were used, and fairly cheap. What would have been payment money on an expensive tractor went into the bank. When it came time to go tractor shopping, the new tractor was paid for when it was picked up. It is a matter of discipline and patience, not wealth, to be able to go for cash deals like that. If there are $X available each month to pay for a tractor after delivery, there are $X available to set aside before buying.
/ Buying used vs new help...... #10
That's great for folks who can do that, but it doesn't help the folks who need the tractor now and can't risk an older machine that might be unreliable.
/ Buying used vs new help...... #11
Avoid Tier IV if you can. You had me scared at first thinking the 3120 was the Mannheim Germany six cylinder of late 60's and early 70's vintage . They never really got the bugs worked out of those tractors transmissions and transmission hydraulics until the 50 series.
/ Buying used vs new help...... #12
For some strange reason, the JD 3120 compact tractor was very quickly replaced by the
3320 as the lowest hp member of the 3x20 series. The 3320 replaced the 4300. I think
the 3120 was sold for only a year or 2.
/ Buying used vs new help...... #13
All really comes down on how you plan to pay for it.
If you have to finance. The Kioti is a way better deal at 0%. Here's some quick numbers.
JD 100% financed at 5.5% would be about 282.00 a month for 60 months. If you just make monthly payments without early payoff total price comes out to 16,920.00
Kioti fully financed at 0% comes to 346.00 month total cost 20,800.00
For 4 grand more your getting a tractor with warranty and 5 more hp it becomes a lot more appealing.
On the other hand if you can put 8-9 grand down and payoff the tractor in a year or two than I would say go for the the JD just for the simple fact that 60 months is a long time and typically another large ticket item such as a vehicle may need to be replace in that span.
/ Buying used vs new help...... #14
What he wrote.
OP - what are your wrenching skills? How much are you going to use it? How important are $$$ to you? What do you have for implements?
I've got two tractors bought used and consider them essential to what I want to do but put less than 100 hours a year on either.
I set aside a budget for tractors and most of that is going towards implements.
/ Buying used vs new help...... #15
Just to suggest the decision is merely a financial one would not be logical to me.
As examples:
1. The used unit . . . because it says JD doesn't mean parts are readily available. How many years was it in production is an issue.
2. Break in. Tp some like myself . . . its s big deal because "break in" can determine the performance of a unit and its efficiency and early wear and tear.
3. Comfort and sizing. If it isn't comfortable and in a size and features you really like . . keep looking.
4. Others have mentioned financing issues and that is true . . . but also what perks does the manufacturer offet on a new unit. Here's an example. I got 5 full years of damage insurance for less than $300.00. It covers all the things homeowners won't like floods, hail, tip over, tornadoes etc.. I don't know what a kioti even looks like . . . but new equipment may have side benefits you aren't thinking of.
5. Another financing issue . . Some manufacturers let you add in other implements with the cheap financing . . which can further change the intrrest cost spreads on a new unit vs. used.
/ Buying used vs new help...... #16
If paying cash, I'd make a lower offer on the used tractor. The dealer came down about 20% when I paid cash for my used tractor. It's still worth almost as much as I paid for it 12 years ago.
/ Buying used vs new help...... #17
I've had no problems with used tractors, unlike my better-off neighbor who just bought an expensive brand new Deere 5055... but that's not what I want to mention: not being a Deere guy, I may be mis-remembering, but I think I would be sure that the machine you are considering isn't one with the aluminum rear end, or plastic fenders. The smallish Deere's have been called out for that stuff here on TbN. Good luck, in either choice.
/ Buying used vs new help...... #18
yessir, that one has aluminum rear axle housings and gearbox. The plastic rear fenders are thick, but the hood
and front panels are thin green resin plastic and $$$ to replace. It is not just the smaller Deeres.
2019 Chevrolet Express 2500 Cargo Van (A61568)
2019 Chevrolet...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2019 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNFL0KG646154 (A61165)
2019 Ram 5500 4x4...
2020 Kubota RTV X1140 (A61166)
2020 Kubota RTV...
New/Unused Electric 3-Wheeler (A61166)
New/Unused...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
