Remote grease fitting?
/ Remote grease fitting? #1
Cord
Richfield, Wi
Resident Architect
I have a grease fitting on my mower that is buried way too deep. I found it only after searching several times because it's so well hidden. There is a hole to access the fitting, but I can only touch it with my finger; can't see the fitting much less grease it. I ended up taking some shields off and was able to get it greased. Honestly, the zerk looks new which isn't good on a 10 year old machine. I think the solution is to provide a remote zerk, but the line will need to be flexible. Wondering if anybody can make some suggestions as to the best way to accomplish this?
/ Remote grease fitting? #2
if it is on a fixed, non moving part, you may have an option , if it is one of the big pipe plug sized zerks. if so. thread a grease gun hose in there, nad then run it to an easy place, then couple that other hose end to a zerk.. attach and grease.
The fitting is the 1/4" size and I believe the grease gun hoses are 1/8" mpt. They make adapters that would work on the bearing side, but I don't know of a bulkhead fitting for the zerk end.
/ Remote grease fitting? #4
Next thought would be a little solder magic with some brake line and some union fittings
Could find a soft brass or cast iron plug or reducer bushing, thread the hose to the inside and tap a next smaller plug for a zero, then add that to the reducer
Might not be an out of the box method, but stepping it thru a couple processes should work
/ Remote grease fitting? #5
Drill a zerk thru, slip fit a piece of brake line over hollowed out zerk, silver solder or braze. Drill sift plug, one side as slip for tube, sweat on, other side tap for zero
Or take reducer, solder in hollow zerk, other side is fem 1/8 pipe. Add hose, couple hose to another zerl
/ Remote grease fitting? #6
Could make one. A piece of aluminum or metal, 3-4" long, 3" wide, drill hole from each end, one hole in middle to meet
the holes from the ends, grease lines hooked to end holes for two zerks. Add more holes on top or side for more lines.
Brake lines would be good for a project like this. Swivel barrel nuts to thread into the block and the zerk hole, if thread size of zerk is the same.
Otherwise cut line and braze zerk on. Bend to fit bolting down as you go.
Standing in one spot greasing all you need to, Priceless.
T.J.
/ Remote grease fitting? #7
If you are talking about this one, in that hole, I made an extension from a pipe removed from a lever gun, a 1/8 coupler and a 1/8 zerk. I will get a picture of it tomorrow.
attachment.php
attachment.php
attachment.php
/ Remote grease fitting? #8
433136-remote-grease-fitting-p5300015-jpg
433137-remote-grease-fitting-femalepipecoupler-jpg
433138-remote-grease-fitting-image_resize-jpg
very similar to what i was thinking too.
/ Remote grease fitting? #9
T.J.
some heavy equipment uses stuff like that.
on our pavement milling machines, there are air over grease tubes and remote lines running many places.
/ Remote grease fitting? #10
This is my extension, works great with the LockNLube coupler.
attachment.php
attachment.php
attachment.php
attachment.php
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
John Deere HX20 (A60462)
John Deere HX20...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
9ft. EZ Loader S/A Boat Trailer (A59231)
9ft. EZ Loader S/A...
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
