lhfarm
A series of heavy downpours this spring and summer washed gravel and mud into one of the small culverts crossing our drive. I should have caught this earlier, but the end result was the culvert was filled at least 5 feet from the outlet end. Did a search here and found some good suggestions, including the use of a high pressure water hose, such as a pressure washer. The culvert is located several hundred feet from the house (600-700'), so I need another option to hooking up my pressure washer.
My wife asked if I could use the 50 gallon tank on my old boom sprayer, so I dragged the spray out of storage and mounted it on the tractor. The sprayer has a 20' handheld line with a small brass fire hose style nozzle, so I thought I'd try using that before I re-plumbed the tank to hook up to the pressure washer. On a side note, the sprayer has been in storage for 3 years or so. I had put oil in the pump and capped the ports, so I was sure it was good to go. Filled the tank and no pressure. Found a cracked fitting on the inlet side and after replacing that, the pump worked perfectly.
I had dug as much of the gravel as I could from the outlet side. Fired up the sprayer and it was clear that the pressure from the nozzle would work, if not especially fast. I had a 10' piece of cooper pipe and I taped the nozzle to one end. I used that setup to wash the clay along the face of the blockage and used a regular garden hoe to pull the gravel to the outlet. It was slow going, but certainly worked. I pumped water from the inlet side to be sure the blockage was cleared.
I still need to drag more gravel out and will be looking for ideas on that. But another problem solved with help from TBN!
