Backhoe MF 750 4wd backhoe
/ MF 750 4wd backhoe #1
rossmichelle
goldcost qld
mf backhoe
Backhoe wont start, have replaced starter motor, new batterys, etc, been checked over by auto electrician and everything fine. Wants to start but stops straight away.What else could it be?
/ MF 750 4wd backhoe #2
Two questions. Does it start and run when you have the starter engaged and then die as soon as you let off the key? Is it a gas motor?
No, It only wants to start, then it dies instantly to nothing, so then turn key off again. It is a diesel motor and it was done up around 6 years ago and not had much work.
/ MF 750 4wd backhoe #4
Have you bled the fuel system? To me it kind of sounds like it's not getting fuel. I'm not sure of the procedure on your particular tractor but the owners manual should have it.
no its not the fuel, it seems that it was the alternator and now fixed the problem 1
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A60352)
LandHonor...
2018 Freightliner M2 106 20ft Reefer Box Truck (A60352)
2018 Freightliner...
40ft 6 Door Shipping Container (A60352)
40ft 6 Door...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
