Backhoe MF 750 4wd backhoe
/ MF 750 4wd backhoe #1
rossmichelle
goldcost qld
mf backhoe
Backhoe wont start, have replaced starter motor, new batterys, etc, been checked over by auto electrician and everything fine. Wants to start but stops straight away.What else could it be?
/ MF 750 4wd backhoe #2
Two questions. Does it start and run when you have the starter engaged and then die as soon as you let off the key? Is it a gas motor?
No, It only wants to start, then it dies instantly to nothing, so then turn key off again. It is a diesel motor and it was done up around 6 years ago and not had much work.
/ MF 750 4wd backhoe #4
Have you bled the fuel system? To me it kind of sounds like it's not getting fuel. I'm not sure of the procedure on your particular tractor but the owners manual should have it.
no its not the fuel, it seems that it was the alternator and now fixed the problem 1
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
New/ Unused Plate Compactor (A61166)
New/ Unused Plate...
2005 John Deere 7420 (A60462)
2005 John Deere...
