   / Your last generator Maintenance Run #451
Not much difference +/- especially from inside the house. Somewhat "deeper" tone to the Champion, maybe. Did the 5 hour "break in" oil change & could see why the early change, lots of silver sparkle to be found in the old oil...
Had some 5w30 Mobile 1 synthetic on hand so refilled with that. May do an early second change just to satisfy myself that the crankcase is clean.
Nick
   / Your last generator Maintenance Run #452
Fired mine up again today... Thanks to this thread as a reminder. Now that I have a battery tender on my Honda 3000is... It is no big deal, actually a total pleasure just have to turn the key! Wife can do it and that is key!
Happy Wife = Happy Life :thumbsup: .
While I would hate to see small gens go the way street bikes did decades back (electric only), it is convenient, and sometimes necessary, to have electric start.
Tho, I have to admit, Briggs did a decent job designing the pull-start on my 7kw - it is easier to pull than my smaller Briggs, on my 2kw gen..... Partly due to the 7kw being a vertical pull, whereas the 2kw is horizontal.
This thread helps me with Time Flying By, and my less than perfect memory...... as a bonus, I've really enjoyed learning about people's different generators, installations, and operating/maintenance reports.
Rgds, D.
Nick
Even at today's (Canuck) prices for synthetic, I consider oil to be cheap, vs. how long most of us expect a generator to be around, and reliable.
I'm going back to your product info link Nick.... I can't remember if propane consumption was posted..... If you do get around to using the propane option, it would be interesting to see what your consumption is. -40 temps can be a challenge for propane :cold:, but can't see that being an issue down your way.
Edit - per the Costco site, looks like:
"Up to 5 hours @ 50% Load on a 20 lb./5 Gallon Propane/LPG tank"
Rgds, D.
   / Your last generator Maintenance Run #455
Finally got around to adding these multi-meters to the basement box that services the generator feed yesterday.
The meters measure volts & amps from the generator feed. The "red leg/black leg" references are to the feed line colors. Each leg is feeding a 1500w heater in this test (plus a small blower on the upper display). The "Kill-a-Watt" is displaying the line AC frequency.
The meters were $12.99 each, delivered, via Amazon Prime (Amazon.com: DROK® Digital Current Voltage Multimeter AC 100-300V 100A Voltage Amperage Meter, AC Volt Amp Testing Gauge Power Monitor LCD Dual Display Voltage Measuring Current Sensing Resistors with Current Transformer CT: Home Improvement). The price includes the doughnut transformer used to read current flow through the wire. I used a 4" box for mounting, hogging out an appropriate opening in a poly box cover plate.
Nick
   / Your last generator Maintenance Run #456
Just changed the fuel filters on my emergency generator - primary and secondary. Gave it a good one hour test run to prove fuel filters.
Primary at the fuel tank and secondary on the generator itself.
The meters were $12.99 each, delivered, via Amazon Prime (Amazon.com: DROKョ Digital Current Voltage Multimeter AC 100-300V 100A Voltage Amperage Meter, AC Volt Amp Testing Gauge Power Monitor LCD Dual Display Voltage Measuring Current Sensing Resistors with Current Transformer CT: Home Improvement). The price includes the doughnut transformer used to read current flow through the wire. I used a 4" box for mounting, hogging out an appropriate opening in a poly box cover plate.
Nick
Thanks for posting that Nick - a good deal, and nicely installed :thumbsup:
Rgds, D.
If my memory is working (?), you had a filter issue a while back Jim........ did you notice a problem again, or is this just proactive PM ?
Rgds, D.
   / Your last generator Maintenance Run #459
Rgds, D.
That was quite a while back I think. Anyway, that time I only changed the primary filter at the fuel tank outlet. This time I changed both - and yes it was a proactive move on my part. Fuel filters are cheap insurance compared to the price of fuel injection pumps.
That was my guess, and I totally agree.... plenty of examples on TBN of people running the tiny filters on SCUTs way too long. Even if it doesn't take out the pump, Past-Due filters like to decide to plug when it's about -40 out.... not my favourite time for fuel maintenance....
It's good to hear that you are not presently having any fuel issues.
Rgds, D.
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2017 Ford F-250 (A55973)
2017 Ford F-250...
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
