JoeBuyer
Banned
- Joined
- Dec 11, 2011
- Messages
- 846
- Tractor
- L5450
I'd try heat first in this situation but if space allows, cutting them off is less hassle as far as I am concerned.
Are you sure they are right hand threads?
I got a Bush Hog 3209 cutter, and I'm trying to get the 1 5/16" bolts off that holds the blades on as I'm replacing them.
The 4 nuts have been soaking in PB blaster for a week, but neither my 3/4" impact wrench (being feed from a 1/2" hose @ 150 psi), nor my 3/4" ratchet with an extension will break any of them free.
I spoke to my dealer about it and they use a torque multiplier in the shop for getting bolts like that loose. Here's a link to one that takes a 3/4" input:
Central Tool 6387 4:1 Torque Multiplier : Amazon.com : Automotive
Does anyone have any experience with these devices? For that price, I wonder if I would be better off getting a monster 1" impact wrench? On the other hand, it would be nice to be able to accurately torque large bolts.
Any other thought on how to break these nuts free? I'm have reservations about using heat given that the bolt are hard to get to and I don't want to cause damage to anything else.
Heat the nut. Don't worry about damaging any seals, the seals are to far away from the nut with to much steel in between the two. It is not uncommon to replace (sacrifice) these 4 bolts.
According to the Torque class I went through at work, any nuts or bolts that have been torqued once, and removed, they should not be used again in an application that requires a torque setting. In other words, nuts or bolts should only be torqued once, and then tossed.
