Do I need a torque multiplier to get these nuts off?
/ Do I need a torque multiplier to get these nuts off? #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
I got a Bush Hog 3209 cutter, and I'm trying to get the 1 5/16" bolts off that holds the blades on as I'm replacing them.
The 4 nuts have been soaking in PB blaster for a week, but neither my 3/4" impact wrench (being feed from a 1/2" hose @ 150 psi), nor my 3/4" ratchet with an extension will break any of them free.
I spoke to my dealer about it and they use a torque multiplier in the shop for getting bolts like that loose. Here's a link to one that takes a 3/4" input:
Central Tool 6387 4:1 Torque Multiplier : Amazon.com : Automotive
Does anyone have any experience with these devices? For that price, I wonder if I would be better off getting a monster 1" impact wrench? On the other hand, it would be nice to be able to accurately torque large bolts.
Any other thought on how to break these nuts free? I'm have reservations about using heat given that the bolt are hard to get to and I don't want to cause damage to anything else.
/ Do I need a torque multiplier to get these nuts off? #2
A little heat will go a long way on removing frozen nuts and bolts. Heat it quick so the heat doesn't have time to travel to areas that can be damaged (seals).
/ Do I need a torque multiplier to get these nuts off? #3
A lot of bolts like that have loctite on them. Heat will break the locktite bond. A fastener that large with loctite on it is really hard to remove. I have had 1 inch plus bolts that I could jump on a 4 ft cheater bar, and it wouldn't budge. A little heat, and it came off easily.
/ Do I need a torque multiplier to get these nuts off? #4
Heat is your best answer. I assume you haven't had these off before. I wouldn't spend the money on a larger impact wrench.
/ Do I need a torque multiplier to get these nuts off? #5
Are you sure they are right hand threads?
/ Do I need a torque multiplier to get these nuts off? #6
I would go the torque multipler route. You might find a used one on ebay. They do work! You just need something to brace the multipers handle against (it wants to turn the opposite way).
What is the torque spec of the nuts? 400-600 lb-ft?
Also consider other uses. What's the torque spec for your loader mounting bolts? If IRCC mine are 390 lb ft and my torque wrench only goes to 200 lb ft. With a multipler set it at 96 lb ft and get 384 lb ft out, probably some losses so set it at 100 lb ft and get close to 400 lb ft out.
Or just get a longer pipe
/ Do I need a torque multiplier to get these nuts off? #7
May be getting close to an irresistible force meeting an unmovable object here.
/ Do I need a torque multiplier to get these nuts off? #8
Like all too many main crank pullies on engines.... I have laid into these with a large impact wrench, sometimes for 20+ minutes, ad long as your compressor can keep up. Heat is the only other good option. Don't be afraid to hammer that impact on it for extended time. Ear myffs help a litfor that.... :)
/ Do I need a torque multiplier to get these nuts off? #9
Some rental yards rent torque multiplers.
/ Do I need a torque multiplier to get these nuts off? #11
Heat the nut. Don't worry about damaging any seals, the seals are to far away from the nut with to much steel in between the two. It is not uncommon to replace (sacrifice) these 4 bolts.
/ Do I need a torque multiplier to get these nuts off? #12
Another vote for heat. I take mine on and off annually to sharpen blades just to make sure they will come off. Could sharpen blades on unit, but get better edge in vise.
/ Do I need a torque multiplier to get these nuts off? #13
Use heat on the bolt. Don't worry about messing up something--it's a brush hog that's built like a tank.
As a last resort, tilt that beast up so you can get to the stump jumper and use an angle cutter with cutting blade to cut through the head of that bolt such that you cut the mower blade off. Then cut the shaft of the bolt to get it off the stump jumper.
Good luck.
/ Do I need a torque multiplier to get these nuts off? #14
You're using impact sockets right? A lot is lost through extensions and unsufficient sockets too. But yea, heat is #1 thing to use. Ask any automotive shop, most guys there should be torch pro's due to the amount they get used.
/ Do I need a torque multiplier to get these nuts off? #15
OK, I'll bore you with another vote for heat but...use an acetylene/oxygen torch and heat the nut to a dull red. Then throw the impact wrench on it and the nut will spin right off.
Heating those nuts will not damage anything. The seals are far enough away as others have mentioned. However, the area, nuts, and bolts will stay very hot for a long time. Best let them cool down on their own. Have lunch, a few beers, or whatever for an hour or so.
On the impact wrench...some of the cheaper wrenches, even in 3/4" or 1", won't do the job like a 1/2" quality (read $$$) impact wrench. Been there, done that.
Edit: And when you put the nuts back on just let the impact wrench rattle on them for a couple of minutes. The torque will be perfect then. :thumbsup:
/ Do I need a torque multiplier to get these nuts off? #16
If heat does't work, cut them off with a torch or grinding wheel. First time I took off my LP blades I had to use heat. My manual says use new bolts and nuts each time as the self locking threads are one timers. If forced to reuse I would put back on with "Locktite". I keep a spare set of blades, bolts and nuts. My 3/4 drive 6 point socket and torque bar work good. Run them up snug w/a !/2 drive impact w/ adapter and torque down the nuts with the bar. My LP nuts are 1 7/16 for some reason.
/ Do I need a torque multiplier to get these nuts off? #17
stop fartin around and cut them off. im an old man but as my old man would always say, "use your head for something other than a hat rack"
/ Do I need a torque multiplier to get these nuts off? #18
A mapp gas torch is cheaper than o/a for small projects. Lowes has an oxy mapp setup you could try too.
/ Do I need a torque multiplier to get these nuts off? #19
That's not a very handy place to cut something off. I have a 600 ft pound impact wrench that I run at 150 PSI. If the bolt or nut has Loctite on it the impact wrench isn't going to budge it. That is what Loctite is supposed to do. It doesn't take much heat to soften Loctite. If I remember correctly Loctite softens at a little over 400 degrees.
/ Do I need a torque multiplier to get these nuts off? #20
It looks like heat is your best answer.
If you are still nervous about it, go down to a welding supply shop and get a 400 or 450 degree "temperature crayon". Make a mark on the bolt head, and heat until the mark melts.
500BBL WHEELED...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
INTERNATIONAL HARVESTER 4 ROW PLANTER (A60430)
INTERNATIONAL...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
SCAN TO RECEIVE TEXT UPDATES (A60432)
SCAN TO RECEIVE...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
