Do I need a torque multiplier to get these nuts off?
   / Do I need a torque multiplier to get these nuts off? #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
I got a Bush Hog 3209 cutter, and I'm trying to get the 1 5/16" bolts off that holds the blades on as I'm replacing them.
The 4 nuts have been soaking in PB blaster for a week, but neither my 3/4" impact wrench (being feed from a 1/2" hose @ 150 psi), nor my 3/4" ratchet with an extension will break any of them free.
I spoke to my dealer about it and they use a torque multiplier in the shop for getting bolts like that loose. Here's a link to one that takes a 3/4" input:
Central Tool 6387 4:1 Torque Multiplier : Amazon.com : Automotive
Does anyone have any experience with these devices? For that price, I wonder if I would be better off getting a monster 1" impact wrench? On the other hand, it would be nice to be able to accurately torque large bolts.
Any other thought on how to break these nuts free? I'm have reservations about using heat given that the bolt are hard to get to and I don't want to cause damage to anything else.
   / Do I need a torque multiplier to get these nuts off? #2
A little heat will go a long way on removing frozen nuts and bolts. Heat it quick so the heat doesn't have time to travel to areas that can be damaged (seals).
   / Do I need a torque multiplier to get these nuts off? #3
A lot of bolts like that have loctite on them. Heat will break the locktite bond. A fastener that large with loctite on it is really hard to remove. I have had 1 inch plus bolts that I could jump on a 4 ft cheater bar, and it wouldn't budge. A little heat, and it came off easily.
   / Do I need a torque multiplier to get these nuts off? #4
Heat is your best answer. I assume you haven't had these off before. I wouldn't spend the money on a larger impact wrench.
   / Do I need a torque multiplier to get these nuts off? #5
Are you sure they are right hand threads?
   / Do I need a torque multiplier to get these nuts off? #6
I would go the torque multipler route. You might find a used one on ebay. They do work! You just need something to brace the multipers handle against (it wants to turn the opposite way).
What is the torque spec of the nuts? 400-600 lb-ft?
Also consider other uses. What's the torque spec for your loader mounting bolts? If IRCC mine are 390 lb ft and my torque wrench only goes to 200 lb ft. With a multipler set it at 96 lb ft and get 384 lb ft out, probably some losses so set it at 100 lb ft and get close to 400 lb ft out.
Or just get a longer pipe
   / Do I need a torque multiplier to get these nuts off? #7
May be getting close to an irresistible force meeting an unmovable object here.
   / Do I need a torque multiplier to get these nuts off? #8
Like all too many main crank pullies on engines.... I have laid into these with a large impact wrench, sometimes for 20+ minutes, ad long as your compressor can keep up. Heat is the only other good option. Don't be afraid to hammer that impact on it for extended time. Ear myffs help a litfor that.... :)
   / Do I need a torque multiplier to get these nuts off? #9
Some rental yards rent torque multiplers.
CATERPILLAR 819 PADFOOT LANDFILL COMPACTOR (A51242)
CATERPILLAR 819...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2022 Western Star Tri Axle Dump (A47384)
2022 Western Star...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
