How to release hydraulic lines
/ How to release hydraulic lines #1
Rally Farm
Catlett
1995 JD 6400
I know this is a dumb question but I just bought this property which came with a 95 JD 6400. I don't have a manual yet and have never owned a tractor before. It has a MX 15 attached and I don't know how to disconnect the lines going to the bush hog. Looks like something needs to release the ball bearings inside the socket. Any help would be appreciated. Thank you.
-Lance
/ How to release hydraulic lines #2
There are no dumb questions. ;)
You just slide/push the outside ring that captures the ball bearings towards the tractor. Do the opposite to reconnect the coupling.
video..(listen carefully due to the Indian accent which makes you feel like you are at Motel6 or have a computer question)..
https://www.youtube.com/watch?v=HyUuOUDMKms
:welcome: to TBN
Thanks, I'll try that.
/ How to release hydraulic lines #4
Make sure you lower it down all the way first, or you will have a hard time getting the lines to reconnect afterwards.
Aaron Z
I'm not sure where the ring would be on these? download_20150618_120159.jpegdownload_20150618_120213.jpeg
It's obviously something simple and I don't see it so its killing me. I will have to go into hiding after I find the answer.
So just pull hard on the hose to remove it?
/ How to release hydraulic lines #9
/ How to release hydraulic lines #11
Sometimes it helps to push forward on the hose you are trying to pull out before pulling it out.
/ How to release hydraulic lines #12
:thumbsup:
I had the thought going through my head that your couplings were of the push/pull vintage.
Glad that you had the expert advise to get it figured out.
One reason I believe they were used, was with breakaway equipment that allowed for the hyd. hoses to disconnect without operator help, thus to avoid pulling a hose apart and have oil spraying all over.
Keep the area clean of dirt so it doesn't get into your hyd. system. The caps help that, but are not the complete answer.
2016 FORD EXPLORER SUV (A67737)
2016 FORD EXPLORER...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A68183)
2017 Ford F-250...
PORTA POTTY (A68842)
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
CONVEYOR BELT (A68842)
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
