How to release hydraulic lines
   / How to release hydraulic lines #1
Rally Farm
Catlett
1995 JD 6400
I know this is a dumb question but I just bought this property which came with a 95 JD 6400. I don't have a manual yet and have never owned a tractor before. It has a MX 15 attached and I don't know how to disconnect the lines going to the bush hog. Looks like something needs to release the ball bearings inside the socket. Any help would be appreciated. Thank you.
-Lance
   / How to release hydraulic lines #2
There are no dumb questions. ;)
You just slide/push the outside ring that captures the ball bearings towards the tractor. Do the opposite to reconnect the coupling.
video..(listen carefully due to the Indian accent which makes you feel like you are at Motel6 or have a computer question)..
https://www.youtube.com/watch?v=HyUuOUDMKms
:welcome: to TBN
Thanks, I'll try that.
   / How to release hydraulic lines #4
Make sure you lower it down all the way first, or you will have a hard time getting the lines to reconnect afterwards.
Aaron Z
I'm not sure where the ring would be on these? download_20150618_120159.jpegdownload_20150618_120213.jpeg
It's obviously something simple and I don't see it so its killing me. I will have to go into hiding after I find the answer.
   / How to release hydraulic lines #6
I suspect that the ring is what the flip up cover mounts to
Aaron Z
So just pull hard on the hose to remove it?
   / How to release hydraulic lines #9
Awesome, thank you.
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
