Quiet window air conditioner
/ Quiet window air conditioner #1
Mysfyt
NE Wisconsin
Kubota L3901
Looking to replace my 6000 BTU window unit and I want the quietest one money can buy. Who makes such a one?
Thanks for the replies! Got a guy coming over tomorrow to discuss installing one. What brands should I consider?
/ Quiet window air conditioner #5
If you are looking for a window unit as you said instead of a split system, I have a couple words of advice.
Most of the modern compressors are a lot quieter than they used to be and it is the fan motor that makes most of the noise. Definitely do not get a unit that has a regular fan blade in front. Make sure it is a squirrel cage type blade as they are much quieter. Some of the rare larger units with large squirrel cages usually have a quieter, slower rpm motor than the compact units that have a small blade operating at high rpms.
Makes aren't nearly as important as they used to be because most of the units are made in Asia under contract and the same make may be made by 2 or 3 different manufacturers in any given year. Generally, larger, heavier models of the same btu are quieter.
/ Quiet window air conditioner #6
. We call them window shakers around here
Thanks for the reply! We'll see how the mini split looks but if its not practical, I'll be back searching for a window unit. I stumbled across a site that had listed a number of different manufacturers units along with the decibel ratings for each, but I can't seem to find it anymore.
/ Quiet window air conditioner #9
I have a daikin 3 zone mini split in our rental house. I did most of the install myself and had a hv/ac finish it off for me. The mini splits are incredibly quiet! They are as quiet as a small fan on low. Here is a truly diy mini split Amazon.com - Breeze Series BR0412W1A 4000-12000 BTU Single Zone Wall-Mount Ductless Split System with 12000 BTU Heat Pump 11.8 EER 17.8 SEER Quick Connect Line Sets and Thru-the-Wall/Window - Freidrich Breeze
It is larger then what you need, but most mini splits can be oversized and not have the short cycle problem that other a/c units have. Mini's have the ability to run on a very low speed instead of just on/off.
Dave
/ Quiet window air conditioner #10
The box stores have 6000 btu units for a Benjamin, I'd just turn up the audio.
Us poor folks got poor ways I reckon. :confused3:
/ Quiet window air conditioner #11
I don't have anything to add, but am interested in your outcome.
BTW, don't most guy's wives want the noisiest system to drown out the snoring? Just kidding...
/ Quiet window air conditioner #12
Mine was a home depot/ ramsound mini split air /heat pump 12000 btu just over $1000.00 very comfortable.
/ Quiet window air conditioner #13
I'm interested in those mini splits as well. May install one in my house. Be nice to not have to take the window a/c out for winter. And it having a heat pump would be a bonus as well.
I don't mind the noise of the a/c myself. I think the hum of the compressor and the fan going in my window a/c is soothing and helps me get to sleep.
Though if I'm talking on the phone it can get loud and be hard to hear the person on the other end of the phone.
lol. That's funny. :)
/ Quiet window air conditioner #14
How much did it cost if I may ask?
Don't mind ha asking. YMMV, but I had a GREE 4 zone installed with heat pump. They had to travel 120 miles to my place for install and did all the lineset covers and custom fit the line length so nice clean install. $5,760 and let me put on credit card for the points.
/ Quiet window air conditioner #15
I will add this... It was a 2-3 man crew that worked sun up to sun down on the install. This was the the 3rd company I had come out and the only one with real experience and knowledge of multi zone. The other two quotes were double and was clear they had no clue what they were doing.
Knew I had the right company when they said, yep we do retro fits like this all the time and yours is a typical straight forward job. Did an A frame like this one with a loft just like this last week.
Thanks C4Ranch! That's in the same area I was quoted for a Mitsubishi unit for two rooms. The sales guy brought out a demo unit and you couldn't hear it run on low, and it was like a whisper on high. Having trouble hearing on the phone without the A/C running, much less when it's grinding away. Thanks to all who replied!
/ Quiet window air conditioner #17
You will find that Mitsubishi is the most expensive. Keep in mind AC units typically share same components and at end of the day they're compressors, condensers, coils and fans.
One feature I was looking for was the "I feel" which allows the unit to measure temp based on the remote control placement vs. where the unit is mounted.
Agree, I was amazed at how quiet they are.
/ Quiet window air conditioner #18
The latest models are all inverter (variable frequency drives) for both compressor and indoor units.
/ Quiet window air conditioner #19
We had the Mitsubishi unit installed in our sunroom. You cannot hear it running. It keeps the 12 x 24 sunroom cool and also keeps the 16x18 utility room cool. This is amazing to me since there is only a 3' door connecting the rooms and it is as far away from the unit as possible. It was $3500 installed, expensive, but worth the money. As I said above you cannot hear it running.
We repainted all the sunroom window frames last fall. There are thirteen windows. It was 90+ outside and inside and all windows were open. We turned the unit on, installed the handles, and cranked all the windows closed. It was cool within ten minutes.
Worth the money.
RSKY
Worth the money.
RSKY
How long ago did you have it installed? That seems like a very reasonable price.
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2018 CATERPILLAR 320GC EXCAVATOR (A65056)
2018 CATERPILLAR...
2015 DRAGON PRODUCTS CRUDE TRAILER (A67714)
2015 DRAGON...
2008 FREIGHTLINER M2 CAB & CHASSIS (A67714)
2008 FREIGHTLINER...
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
