Quiet window air conditioner
   / Quiet window air conditioner #1
Mysfyt
NE Wisconsin
Kubota L3901
Looking to replace my 6000 BTU window unit and I want the quietest one money can buy. Who makes such a one?
   / Quiet window air conditioner #2
ductless mini split 0 noise
Thanks for the replies! Got a guy coming over tomorrow to discuss installing one. What brands should I consider?
   / Quiet window air conditioner #5
If you are looking for a window unit as you said instead of a split system, I have a couple words of advice.
Most of the modern compressors are a lot quieter than they used to be and it is the fan motor that makes most of the noise. Definitely do not get a unit that has a regular fan blade in front. Make sure it is a squirrel cage type blade as they are much quieter. Some of the rare larger units with large squirrel cages usually have a quieter, slower rpm motor than the compact units that have a small blade operating at high rpms.
Makes aren't nearly as important as they used to be because most of the units are made in Asia under contract and the same make may be made by 2 or 3 different manufacturers in any given year. Generally, larger, heavier models of the same btu are quieter.
   / Quiet window air conditioner #6
. We call them window shakers around here
Thanks for the reply! We'll see how the mini split looks but if its not practical, I'll be back searching for a window unit. I stumbled across a site that had listed a number of different manufacturers units along with the decibel ratings for each, but I can't seem to find it anymore.
   / Quiet window air conditioner #9
I have a daikin 3 zone mini split in our rental house. I did most of the install myself and had a hv/ac finish it off for me. The mini splits are incredibly quiet! They are as quiet as a small fan on low. Here is a truly diy mini split Amazon.com - Breeze Series BR0412W1A 4000-12000 BTU Single Zone Wall-Mount Ductless Split System with 12000 BTU Heat Pump 11.8 EER 17.8 SEER Quick Connect Line Sets and Thru-the-Wall/Window - Freidrich Breeze
It is larger then what you need, but most mini splits can be oversized and not have the short cycle problem that other a/c units have. Mini's have the ability to run on a very low speed instead of just on/off.
Dave
   / Quiet window air conditioner #10
The box stores have 6000 btu units for a Benjamin, I'd just turn up the audio.
Us poor folks got poor ways I reckon. :confused3:
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A58017)
1999 INTERNATIONAL...
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
