Broke Hydrostat twice? Why?
/ Broke Hydrostat twice? Why? #121
I opened up the pressure test ports, seen here. Behind them was a double spool valve, all
removed to check for cleanliness. Very clean in there.
/ Broke Hydrostat twice? Why? #122
Then, the forward and reverse pressure relief valves were removed and checked for dirt,
or a fractured spring. These open at just under 5000psi, according to the manual. To
test them properly, you put a 10,000psi gauge on the left or right test port (see above)
and make the running tractor go to relief. I have the gauge and fitting here, but
have not had the oppy to do this test.
Both were clean and intact. The nut that holds it together is welded so someone (like
yours truly) does not easily adjust it. They look almost exactly like the RVs on my
Kioti.
Passage ways to the valve plates for both pump and motor were clear and clean.
/ Broke Hydrostat twice? Why? #123
Hanging on your every, above-my-head word LOL
Say... Dfkrug... Do you know who makes the HST unit in my Iseki built Massey 1648 by chance...?
/ Broke Hydrostat twice? Why? #124
I could not even guess who made it. I also never heard of the company who made this TYM unit.
BTW, I am a Spartan, lower right on your avatar...nice Sparty.
/ Broke Hydrostat twice? Why? #125
Go Green & White!
Doesn't TYM make their own HST's?
And thx... Figured it was worth a shot. No one seems to know (our be willing to disclose) who makes the HST in mine. Figured with your exposure you may have had some insight.
/ Broke Hydrostat twice? Why? #126
Finally, the pump.
The maker is Tong Myung Heavy Industries, LTD. This is a South Korean maker of
industrial products, founded 1997. If you look closely, you can see one of the
splines on the input shaft is broken off. That is strange. Susanne may have a better
picture of that.
/ Broke Hydrostat twice? Why? #127
And here is our problem.
Looking at the pump's valve plate, you can see erosion of the metal next to one of
the ports. This is the area where oil is pumped by the pistons at maximum pressure
into the forward port. The reverse port would have sustained the same pressures,
but it got used far less than the forward port, so it was not damaged.
My conclusion is that the oil overheated and boiled at the place where you see the
metal erosion. This was likely caused by the AUX detent valve being ON for an
extended period (perhaps minutes), which forced the full output of the implement
pump through the system relief valve.
/ Broke Hydrostat twice? Why? #128
Here is an annotated photo of one of the fixed valve plates and the rotating cylinder
block. The ports in the valve plate experience flow in either direction, depending
on the tilt of the swash plate. For the motor, the swash plate is at a fixed angle,
so the direction of flow from the pump will determine which way it spins.
/ Broke Hydrostat twice? Why? #129
Could the worn/ eroded parts be made by a machine shop? If so it seams like you could make it a working unit again and have a spare.
I would think about adding a temperature gauge to monitor the oil temp as well as a way to keep that lever from accidentally moving to a position to cause the hydro to go into bypass.
/ Broke Hydrostat twice? Why? #130
This has been a very interesting thread to follow. Thanks to Bob and dfkrug for sharing.
Now I wonder if this part can be purchased and, if so, for how much.
/ Broke Hydrostat twice? Why? #131
By the way, the hydraulics on my Korean-built Kioti tractor are made by Mita Oleodynamica of Italy.
I do not know if that includes the HST.
/ Broke Hydrostat twice? Why? #132
Sadly, TYM is one of those companies who refuse to sell any HST subassemblies. I think this HST
would work fine if you just replaced the valve plates. They are a soft bronze-type material, and easily
scratched with a fingernail. Make one? Perhaps, but what material would you use?
My experience with JD and Kubota has been that they WILL sell HST subassemblies, but I do not
know if that includes all tractors. McCormick (Landini) would sell nothing inside their HST for my GX50H.
My Kioti parts book lists parts separately inside the HST, but I have not tried to buy any. Kioti
has a reputation for requiring excessive lead times for unusual parts, however.
/ Broke Hydrostat twice? Why? #133
DFkrug,
The oil going over the relief would also tend to aerate the oil which leads to cavitation which will erode metal just like in the picture. This would also explain the score marks on the motor since trash from the pump goes into the motor.
nice work and great right up
/ Broke Hydrostat twice? Why? #134
DFkrug,
Yessir, that's a good point. Indeed, if you look closely, the surface of the wear area looks like inverted craters.
Thanks for contributing, OnS.
/ Broke Hydrostat twice? Why? #135
So what about the broken spline, what does that indicate? Any part of cause and effect on this particular HST, or is the manufacturer rebuilding used/broken/returned under warranty, HSTs and selling them as replacement units, possibly?
Are you saying the reverse gearing did not get scalded by the excessively hot fluid from the AUX valve being on accidentally, without the OP's knowledge, and thus did not sustain the level of damage the forward gearing did?
It may be me, but I don't see the wear you refer to on the port(s) etc. I do see subtle scratches on some metals you showed and some darkening of the metal discs in others. Can you possibly circle the exact areas you're referring to, if not too much trouble, for us feeble minded older guys?:confused3:
/ Broke Hydrostat twice? Why? #136
I would guess that foward got used more than reverse while the aux valve was on and that caused the wear (think of it as holding the plate in front of a sandblaster when this was happening, foward got held in front of it longer than reverse, so it wore worse).
This is the reason I really don't like idea of a detented aux valve...
Look at: http://www.tractorbynet.com/forums/...434394364-broke-hydrostat-twice-why-hst_6-jpg
Follow the right hand groove toward the left hand groove and there is an indentation/depression that is not there on the other side.
Aaron Z
/ Broke Hydrostat twice? Why? #137
Yes, that's right. Depending on your usage, FWD may see 10x or 20x the action
that reverse does. Bob reports what may have been a gradual deterioration in
performance.
There is nothing wrong with detented AUX valves....I need them for running
a backhoe, or a hyd PHD, or hyd concrete mixer. Mine is very hard to
accidentally engage. That's really the issue.
On my first tractor, an old L2550 Kubota, the 3-point lever was easy to accidentally
put into relief at the top of its travel, and the range shift was super-easy to
knock into neutral when getting on/off the tractor. In the first case, you could
really hear the engine struggle. In Bob's case, not so much.
/ Broke Hydrostat twice? Why? #138
Perhaps they need a lockout so you have to push to the side in addition to forward or back to lock them in...
The idea just worries me with some of the drivers we have and their lack of attention to things like the sound of a relief valve bypassing.
Aaron Z
/ Broke Hydrostat twice? Why? #139
To me that cavitation erosion looks like the result of low charge pressure or air entrapped in the oil. The port plate wear shown in an earlier picture does look like lack of lubrication probably caused by oil getting too hot; however, my book on "Applied Failure Analysis" says overheated oil causes ash residue on the surfaces and I don't see that in the pic. I tried linking to an illustration of cavitation erosion but it linked to a purchase document rather than to the picture.
/ Broke Hydrostat twice? Why? #140
Sure was cavitation, I was going ask how it was getting air but Roy posted the reason. Thanks for taking the time to do this for us. It's very interesting and helpful. I almost forgot to thank Bob for getting the unit to you, Thanks Bob!!
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
