dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,803
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Say... Dfkrug... Do you know who makes the HST unit in my Iseki built Massey 1648 by chance...?
I could not even guess who made it. I also never heard of the company who made this TYM unit.
BTW, I am a Spartan, lower right on your avatar...nice Sparty.
Could the worn/ eroded parts be made by a machine shop? If so it seams like you could
make it a working unit again and have a spare.
I would think about adding a temperature gauge to monitor the oil temp as well as a way to keep that lever from
accidentally moving to a position to cause the hydro to go into bypass.
And here is our problem.
Looking at the pump's valve plate, you can see erosion of the metal next to one of
the ports. This is the area where oil is pumped by the pistons at maximum pressure
into the forward port. The reverse port would have sustained the same pressures,
but it got used far less than the forward port, so it was not damaged.
My conclusion is that the oil overheated and boiled at the place where you see the
metal erosion. This was likely caused by the AUX detent valve being ON for an
extended period (perhaps minutes), which forced the full output of the implement
pump through the system relief valve.
DFkrug,
The oil going over the relief would also tend to aerate the oil which leads to cavitation which will erode metal just like
in the picture. This would also explain the score marks on the motor since trash from the pump goes into the motor.
nice work and great right up
I would guess that foward got used more than reverse while the aux valve was on and that caused the wear (think of it as holding the plate in front of a sandblaster when this was happening, foward got held in front of it longer than reverse, so it wore worse).Are you saying the reverse gearing did not get scalded by the excessively hot fluid from the AUX valve being on accidentally, without the OP's knowledge, and thus did not sustain the level of damage the forward gearing did?
Look at: http://www.tractorbynet.com/forums/...434394364-broke-hydrostat-twice-why-hst_6-jpgIt may be me, but I don't see the wear you refer to on the port(s) etc. I do see subtle scratches on some metals you showed and some darkening of the metal discs in others. Can you possibly circle the exact areas you're referring to, if not too much trouble, for us feeble minded older guys?:confused3:
This is the reason I really don't like idea of a detented aux valve...
Perhaps they need a lockout so you have to push to the side in addition to forward or back to lock them in...There is nothing wrong with detented AUX valves....I need them for running
a backhoe, or a hyd PHD, or hyd concrete mixer. Mine is very hard to
accidentally engage. That's really the issue.
