Well problems
/ Well problems #21
The 230v hots can be connected either of the two blacks, polarity won't matter. The green wire is a ground which will connect back to "ground" somewhere near where your pressure switch is located (assuming your wiring has the extra wire for a ground).
/ Well problems
Thannks, this is what I thought, but I had a small voice saying, don't wire this thing to run backwards and have to pull it agian.
/ Well problems #23
Glad you got it out - 100' isn't too bad to pull, just make sure you tape up the wires to the pipe every 10' or so and when dropping the pump back in the well, I like to do a "test run" meaning when the pump hits water drop another 5' and wire it up and test it for a few minutes before dropping the whole 100' in the well.
Also make sure you have an old towel to wipe off the pipe (grass, dirt etc.) before dropping it in. (The last time guys did mine 365' they replaced the pump 2x due to grass getting into the pump).
As others have said, get an ammeter - you can find Amprobe brand used for $30 or less - they are invaluable in checking these types of problems.
Last make sure your tank pressure id 30-50 switch setting tank should be @ 28 PSI. Good luck and let us know how you make out.
/ Well problems
I probably would have it back together by now but he didn't have a safety rope in it originally and I decided that in case I ever have to do it again I wanted to add a safety rope. I figured $20 worth of rope is better than risking the PVC breaking and dropping the pump into the bottom of the well.
/ Well problems #25
While were on the subject of pumps, wondering if anyone else has their pump electrical feed from an outlet? I did this back when I put the pump in as a means to totally disconnect/isolate the control box and pump from the the rest of the house wiring when I know a thunderstorm is coming. Figured if it's not connected it's less likely to get taken out if a lightening hit causes a surge in the house wiring. The outlet is keyed to only take a special type of plug.
/ Well problems #26
In the post I have with the picture of the control box, the tip of an Amprobe is just visible on the yellow wire out of the control box. I've had low water issues and the Amprobe gives a clue as to how much water is available, so it has a semi-permanent home on the wire.
/ Well problems #27
Also on the lower right side of the control box I installed a neon pilot lamp to show when the pressure switch is closed to run the pump.
/ Well problems #28
Looks like you have a 3 wire 1/2 HP with capacitors and motor O/L in the box. I have my pump on a separate breaker so it's a matter of turning off the breaker - never have seen a plug set up like you have - would it not be just as easy to pull the disconnect above that plug (unless it provides power to other devices?)
Question - how can you tell the water level from the amperage? Usually the amperage at low pressure is higher then as the pump reaches shut off the amperage drops (more water being pumped at lower pressure = higher amperage).
/ Well problems #29
Having once had a lightening hit many years ago that managed to jump a few places that had a pretty fair distance between, yes the disconnect does break only the power of the pump, but the gap it has when open isn't that great. Pulling the plug widens the gap considerably and hopefully lessens the susceptibility to a hit on the pump($$$$). I'm particularly paranoid about lightening and besides the pump, all electronics and computers get unplugged when a storm nears.
The amperage is more of an indicator of the volume of water the pump is delivering and if the water gets low the volume rate delivered is lower and also the amps. Mostly concluded this from observation through the day of water usage and a well that recovers not too quickly. Had the well fracked a number of years ago and probably due again.
/ Well problems
Ok, so water is on. Started pulling at 9 am, finished at 4 pm. 1.5 hours going to Lowe's for pump. 30 min to Ace for rope; 30 min too Ace for 1-1/4" to 1" reducer bushing; 30 min back to Ace for some 1" coupling; some 90's.
Few observations: I sure hope those water proof butt splices are really water proof...
I pulled all 100 ft of 1" PVC riser as a single piece (it's thread sch-80 white pvc). Wasn't too bad to pull; but needed wife to walk the end back when I got around half out.
Old pump (.7 hp, 15 gpm) has smaller outside diameter then new one (3/4 hp, 10 gpm) and for some reason didn't sit as low in the casing as the old one. Kinda wonder is the old smaller diameter was in silt and sand, and new one set on top of that? It was most definitely sitting onb bottom... hope this doesn't come back to bite me in the butt, or at least doesn't for a long time. I've always had issues with sand and sediment in the well.
As a general question; what does the bottom of the casing look like. Obviously the casing is a 4" pvc pipe, probably basic DWV sch-40; but does the bottom just sit on the native sand, or is there a 4" well point on the bottom; or a piece with slits like a french drain?
Edit: actual pulling was about 15 minutes, and changing pump was maybe 30; had to do a lot of calling around, 2 TSC's, 2 Aces Hardware, Home Depot, and 2 Lowes'.
Re-edit: $369 plus tax for pump, $5.99 for water proof splices (baught two packs, just in case), 1-1/4" to 1" galvanized reducer bushing (could get one out of old pump) $5; pipe dope $5; 100 ft 1/4" nylon rope $9.99; 2 ea 1" 90' and 2 1" couplings at like $0.69 each.
Prices I got on phone; "$1,000 best case" and $950 plus $1/lf.
/ Well problems #31
Paul, I am coming in late to this discussion but will offer these thoughts:
I have not used the "waterproof" connectors. The pros I had work on my wells just staggered the connections a few inches and connected the wires with butt crimp splices then taped them individually with about 8 layers of Scotch 33 electrical tape. No problems with that in 20 years and I have done the same in the shallow (110') well I maintain. The shallow well has the 3/4 hp pump on 3/4" black plastic and I have pulled it several times by hand. I made a clamp for the pipe using two 16" pieces of 2x4 and some all-thread rod. the clamp just rests on the top of the casing.
The bottom of the casing is likely perforated with holes or slits. One pro installation used 4" pvc that they cut slits in with a circle saw. If you have had sand problems in the past and if indeed the pump is resting on sand, you will likely continue to have sand problems. Knowing this, I would first determine the static water level then pull the pump up as high as I felt I could while still maintaining it well below static level. You will then need to closely monitor the well to ensure it does not over-pump the well.
I have another well, 700' deep with a 5 hp pump set at about 300' on 1.5" steel pipe. This well has always made a lot of very fine sand after about 1 minute of running and until it has run for about 2 hours. The pump has been in about 20 years and is beginning to trip the breaker if it runs for more than about 5 minutes. When it finally gives up, I plan to replace the pump with a 3/4 horse pump in the hope it will not pull sand up from the bottom of the well. I dont need the flow of the 5 hp pump any more.
Also, if you notice the water becoming smelly or bad tasting over the next few days, pour a gallon of bleach in the well and let it sit overnite to kill the bacteria. It is not uncommon to have a bacteria problem after working on a well.
HTH
/ Well problems #32
I discovered these little guys while building my off-grid system. They are surge suppressors / clamps -- they essentially give a quicker path to ground when it exceeds a specific voltage, clamping the lighting strike. Very cool! I've installed several of them as required by code, and a few extras on spendy equipment. Installs right into the knockouts on any panel and wiring takes 5 minutes.
This particular one is made for 120/240v applications and will stop a direct lightning strike. Made by Midnite Solar.
~Moses
/ Well problems
So, now I have the old pump ... can and or should I rebuild (if Cheap with a capital C) it, get rid of it, throw in the woods for future generations to hit with bush hog? When I asked the pump guys about rebuilding, they said the manufacturers make them basically in repairable now. Of coarse he also has a reason to try to sell me a New pump (or sell a rebuilt as a New)
/ Well problems #35
That big box store is nowhere near the quality that a professional well man would use. The motors are cheaper made and the pumps are cheaper made, just like everything else you would buy in a big box store. You'll be lucky to get 3-5 years out of it. Also, I'm not sold on the butt connectors. I've always used tape and butt splices and never had one fail. Good job getting the pump in/out of the well and getting your water going.
/ Well problems
On the button splices; I actually gooped with red RTV and wrapped with tape too. On quality, I can't say; I Do know the new one was significantly heavier, but that's cause the body was cast iron, old one was stainless. Impellers look to be plastic in both... neither where exactly Flypht or Myers
/ Well problems #37
The motors themselves are made cheaper and I've confirmed this with Franklin. It will last you about 3-5 years so you're good, just be aware that the quality is nowhere near the same as a professional grade, just like almost everything else in the box store. The pumps themselves almost never fail, it's usually the motors that give out first.
/ Well problems
Ok, so everything is still working but I have another related question. How long should the pump run when it kicks on: I have a 26 gallon bladder tank. Should it run for a minute or two; or for 10-15 seconds?
/ Well problems #39
26 gal tank should be about 10-12 gallon drawdown so about 70 seconds run time with no other draw on the water
/ Well problems
Thank you. I might just replace the switch too; because it don't know what it's set at. I do know if running about 20 seconds per cycle; which I didn't think was right. I've got the air right at 28 psi (which should be right for 30/50 switch) but #1: I'm not sure if it's 20-40; 30-50; or 40-60; and I've played with the adjusting nut, so no idea what it is at now.
Do you guys put a pressure gauge in, or is there any benifit? Switch is probably $15; and not a bad job to redo, but I'm wondering if there's any reason to put a pressure gauge inline, and adjust my pressure switch to a good factory setting?
