Buying Advice Snowblower Attachment for a C Series Toolcat?
   / Snowblower Attachment for a C Series Toolcat? #1
TK Steingass
Member
Bucksport, ME
None
Greetings Fellas:
Currently I'm looking for a used 2005 Toolcat C series, primarily because they're in the $20,000 range - I don't want to spend $55,000 for a new G series, period. I'm hoping to find one with less than 1500 hours.
In looking at the snowblower attachments on the Bobcat website, they list ones for the G series. Can I still get one for a C series or do I have to modify the C series to use the newer blower attachment?
thanks in advance,
Tim
   / Snowblower Attachment for a C Series Toolcat? #4
I use a bobcat snow blower with my "A" unit. As stated above you will need to match the gpm of your unit with the snowblower. My gpm is low compared to the later series (approx 16-18 gpm) so I was set up with a low flow high torque motor to avoid stalling the snowblower impeller.
If you are buying bobcat then talk with your dealer for more details. If you are buying third party then ask lots of questions about the setup of the snowblower motor.
Best of luck. Let us know what you decide to get.
Thanks for the input - I was concerned about the attachment method. So the quick attach feature is the same for all series?
   / Snowblower Attachment for a C Series Toolcat? #6
Yep, the same and for most skid steers and compact telehandlers.
attachment.php
   / Snowblower Attachment for a C Series Toolcat? #7
Thanks for the information - I'll look closer at them.
   / Snowblower Attachment for a C Series Toolcat? #9
I have a 'D' Series with a 72" Bobcat snowblower on my Toolcat. You should know that besides a variety of widths, they also offer the snowblower with two motor options. A lower torque, but higher speed fan that blows the snow further but doesn't have the torque to really dig into wet, heavy snow quickly. It will work in heavy snow, but you will be going slower and not throwing the snow as far. The high torque motor package will chew thru about anything but doesn't throw the snow nearly as far. Determine how far you need to throw your snow and the type of snow you typically have and pick the motor package that best meets your needs.
DEWFPO
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Hydraulic Hoses (A53316)
Hydraulic Hoses...
2016 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2016 MACK ELITE...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
(INOP) KIOTI CK35 TRACTOR (A51406)
(INOP) KIOTI CK35...
