Welding a Small Part
/ Welding a Small Part #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
Trying to decide MIG vs gas to make this clevis. Weld has to be strong.
The nut is 3/8 -24. Tube is 3/4" DOM, 3/16" wall, 1" long.
The tube is drilled out on the end to make a press fit lip for the nut. To hold it straight and also improve the weld. The lip is 1/16 wide and 3/32 deep.
For gas I am thinking #2 tip and maybe 3-4 lbs pressure.
For MIG I would use settings just under 1/8" and .030 wire.
I don't want to screw it up. I did make a third part to practice on first though.
Wonder what others would do here.
Thanks.
/ Welding a Small Part #2
I'd put a bolt with copper anti-seize through it to hold it in place, use Mig and tack opposite points like cross-torqueing a set of lug nuts (1,4,6,3,5,2). Don't try to weld a continuous bead all the way around - get it solidly tacked down at the corners of the nut first, then the faces in the same pattern. Avoid putting a lot oh heat in one place, and heat opposite sides to even out the temperature.
/ Welding a Small Part #3
I've welded stuff like that hundreds of times with just a stick welder. Sometimes I put a long bolt and washer through it to keep it aligned while welding, then I immediately drop it into a bucket of used engine oil. They've got some 1/8 electrodes at TSC called Tempering Electrodes that I use if I want the thing bullet proof.
/ Welding a Small Part #4
I don't have a gas welder. If it has to be strong I would use a stick VS a mig.
/ Welding a Small Part #5
It's a 3/8" bolt, guys - how strong does it have to be? Mig will do the job, and is far easier for a non-pro welder on a part this size. I'd Tig it, but that was not mentioned as an option - but neither was stick.....
/ Welding a Small Part #6
Yeah, I would use the TIG as well since it would look better, but as you said, that wasn't listed as an option. I have zero experience with a torch and just assumed everyone on this forum has a stick welder. With MIG I always wonder about penetration. On parts like this I don't sweat overheating because I temper it when done.
/ Welding a Small Part #7
This is how I would do it also.
Terry
/ Welding a Small Part #8
Then you don't know how to MIG weld properly. They put ships together with MIG welders. If you're worried about penetration, then you're using wire that's too small with not enough amperage.
I have a 300 Amp MIG and with 1/16 wire I can do 1/2-inch steel with a single pass.
Welding is:
1. Correct weld joint preparation.
2. Clean metal at the weld joint.
3. Matching the electrode size and amperage to the metal thickness.
If you do those three things correctly, there is no problem with penetration no matter what kind of welding process is used.
/ Welding a Small Part #9
Granted I personally do not use MIG. But if you think I do not know how to weld properly- well there just isn't enough bandwidth to show the pics of the hundreds if not thousands of trailers and other items I have built over 40 years using a stick welder. Custom gates, railings, trailers, implements, and even buildings. Recently welded a tiny eye onto a broken stainless steel tang to restore a WWII German paratrooper knife. Welded my own front end loader and sub frame from stock angles, flats, and sq. tube including the bucket.
/ Welding a Small Part #10
Tig welding would be my first choice, then Mig. I too would put a bolt through it. I'd use .023" wire, tack 4-corners, and weld opposite flat spots.
To get good penetration with Mig, all you need is power! :D
Many thanks for detailed suggestions. I do have a stick welder, old Thunderbolt AC/DC, but no TIG.
I think I will use the MIG (Miller 211), corners first, then faces, .023 wire.
I was just going to let it cool in the air but I can drop it in a bucket of oil if there is an advantage to that.
/ Welding a Small Part #12
Actually,Pat there's no reason for not gas wring it either. You could do as neat a job as tig.
Terry
/ Welding a Small Part #13
It's a good idea, as it helps restore the proper hardness to the steel.
I started out gas welding in my Dad's shop when that was all he had, so that is what I think of first even though I guess it is pretty much obsolete!
/ Welding a Small Part #15
I have a Miller MM210. Plenty of machine for the task at hand. I'd use .030, but .023 will work just fine. You COULD use oxy/ace to weld this, but it would not be my first, second, or third choice.
/ Welding a Small Part #16
The oil is an old trick that a guy who makes custom springs taught me. I used to just cool things down with water and you do get some tempering, but the oil works much better. Now on larger pieces you just have to let the air cool it down and be more careful with over heating.
/ Welding a Small Part #17
you are about $100 away from having a scratch start TIG rig with your Thunderbolt if you rent your argon cylinder.
/ Welding a Small Part #19
there you go. If you want a 17V 150 amp torch they are somewhat cheaper. But in any case for around 100 bucks more or less, you are welding TIG.. if you cant rent a bottle. If you have to buy the argon cylinder, well add some more.. depending on the size you buy.
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A60736)
2019 INTERNATIONAL...
