John deere 4230 axle seal
   / John deere 4230 axle seal
i try what tx jim says
manuel says you have to remove wheel.
Do you have 5 bolts on the senter of you rim ? 2 Standing out (looks as if it is loose ? Then you have the rachet sisteme to use ! First looses the 3 bolts then screw in that 2 bolts to ******* the wedge then you can turn the bolt on the side to adjust the wheel in or out !
Twisted off one of the three bolts so I cut it out. Wedge will not budge.the bolt that turns out the wheel is frozen
Tight. Put as much force on the two jackoof bolts as I could plus a sledge hammer on the two screw that hold the wedge.I get nothing.
   / John deere 4230 axle seal #13
Try hitting end of axle with a big hammer as recommended by JD or make a pipe to slip on axle that is cut out so it only contacts the wedge that you're trying to loosen.
   / John deere 4230 axle seal #14
Remember to jack-up that wheel ....turn it until the wedge is under........ and remember to remove the c-clip at the end of the axle
My guess would be to have the wedge i want to remove on top or am i wrong?
   / John deere 4230 axle seal #16
WRONG wedge that needs loosened needs to be on the bottom of axle.
|Got her off,took about 20 hits with a sledge on the axle,
thanks guys.
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
