Front wheel bearings failed L5740
/ Front wheel bearings failed L5740 #1
Complete Turf Care
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
Yesterday, I was loading sod with my front end loader and I could hear and feel a chatter. Suddenly, it got a lot worse and the left front wheel locked up. It would not roll at all.
When I looked at it, oil was pouring out.
Turns out the bearing failed. It must have been bad for a while, because there is quiet a bit of damage in there. Of course none of the local dealers have any of the parts in stock, and everyone is closed for the holiday Monday.
My point is.....check your front wheel bearings. I never had any indication that it was going bad. Everything has been greased regularly, and there was plenty of oil. I have put a lot of hours on it this spring, but had I noticed it earlier, there would have been a lot less damage.
I'll try to get pictures of everything tomorrow.
/ Front wheel bearings failed L5740 #2
What was the apprx FEL load and how much counterweight did you have in the 3pth ?
Br / Marcus
Br / Marcus
I would say the load on the FEL is about 700-800 lbs. I was on the 4th roll of sod for the day. I had to run back to my shop and get my New Holland TC45A to load the other 24 rolls. And I have my tiller on the 3ph which I would estimate to be about 1000-1200 lbs.
But, I don't think that had anything to do with the failure. It looks like the bearing had been bad for a while, but I had never noticed it. I've been using the tiller a lot lately, and my laser grading blade. Not much use of the FEL lately.
/ Front wheel bearings failed L5740 #4
How many hours do you have on your machine?
/ Front wheel bearings failed L5740 #5
The bearings isn't great able is it? I grease the fitting on the top of the spindle but I thought that was for the upper ball joint and the wheel bearing was either an oil bath or a sealed unit.
About 540. It's a 2011 machine that I bought about a year ago with about 275 hours on it.
/ Front wheel bearings failed L5740 #7
Wow, that is real low hours to have such an issue.
If you fix it yourself, please take photos of the repair. I'm also curious on the bill for this one. Thanks for posting this.
/ Front wheel bearings failed L5740 #8
My L5740 failed in January but gave me warning. One day after plowing snow I noticed the left front was wet. I thought it was just that I had been working hard and it was snow melting. Next time I plowed I checked it and found the left to be wetter yet. This time I engaged my brain after putting the tractor in the garage, raised the front end using the loader and sure enough there was free play in the wheel. I had my dealer ship me both bearings and the seal. When I took it apart I found the retainer broken but the balls and races still looking good. There was light rubbing from the drive gear hitting the case. New bearings, seal, and oil and it's running fine. Having read about the number of people having front bearing failures makes me wonder if I should keep a spare set. Cost was about $90 plus shipping. That included a new o-ring housing seal. My tractor had 650 hours at failure.
/ Front wheel bearings failed L5740 #9
Koyo bearings too, not some off brand. Glad I have a large frame under my loader. That looks to be possibly expensive if it completely failed.
There is a good bit of scars on the shaft where the bearing sits, and my mechanic (my brother) thinks that the new bearing will not seat on the old shaft, so I'll order a new shaft. Also, you can see the retaining ring is broken. I'll get pics of the gear later today. I'm thinking this is going to end up around $1000.
/ Front wheel bearings failed L5740 #11
There is a good bit of scars on the shaft where the bearing sits, and my mechanic (my brother) thinks that the new bearing will not seat on the old shaft, so I'll order a new shaft. Also, you can see the retaining ring is broken. I'll get pics of the gear later today. I'm thinking this is going to end up around $1000. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/426368-front-wheel-bearings-failed-l5740-014d8dc861c5c97f9f0fff20d4a545532a33d45218-jpg"/>
Wow, does the wear feel worse than it looks? I would assume the shaft was fine.
Now the part that worries me, if this went, will the other side go?
I'm going by what my brother recommended for the shaft. He has worked for the local John Deere dealer for about 25 years. And, yes, I'm afraid the other side will go out too. I'm fixing to head over to the tractor this morning and I'll check the other side to see if it's got any play. (It's on a job site about 40 miles from my shop).
/ Front wheel bearings failed L5740 #13
Well hopefully it's just a fluke and the other one lasts.
As for your brother, he sounds as he has more experience than me. I've never take an axle out of anything. (Or had to inspect one)
The only thing I know is dirt and grease don't get along.
Got the parts ordered this morning. They should be in Wednesday morning because today is a holiday. About $280 plus freight, and 2.5 gal. of oil. Not as bad as I was expecting.
The gear teeth are chewed up a good bit, but I decided not to change it now, because I would have to change the other gear that drives this one too, and that would be a lot more work.
I also lifted the other front wheel and could not detect anything being loose. Hopefully it holds up for a while.
/ Front wheel bearings failed L5740 #15
Well $280 is much easier to swallow than 1k.
Is this repair pretty straight forward? Unbolt, remove, Slide back together and add fluid?
/ Front wheel bearings failed L5740 #16
I would consider it a weak or bad bearing from the beginning. This is a rare failure. Especially at that many hours. But like you, I'd be paranoid about it. Glad the parts were cheaper than expected.
/ Front wheel bearings failed L5740 #17
I believe I'd take a die makers fine india stone and clean up the teeth a bit, looks like they are chewed a bit. I'm curious as to what lubricant you are putting back in.... Myself, I use 90 weight GL5 hypoid oil in both muy Kubota's front drives.
What a bummer.
It's never that easy. But, it all came off in a few minutes. One thing is that we will have to remove the old wheel studs and put them in the new shaft/hub. Otherwise, with the right tools, it should not be too hard. But that's why I've asked my brother to do it. He has all the tools in his truck.
What a bummer.
I have been researching what oil to go back with. I asked the parts guy at the dealer what oil it needed, and he said either hydraulic oil or gear oil. I told him the oil that was in it was red, and he said that's hydraulic oil. I just went through my owners manual and there is a section on how to change it and it says to look for 'lubricants' in the 'maintenance' section. But I can't find a 'maintenance' section in the manual. This is a pdf version of a manual that I ordered online, and not a hard copy.
/ Front wheel bearings failed L5740 #20
Here is an expanded view of the parts. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/426461-front-wheel-bearings-failed-l5740-kubota-pdf"/>
sorry, I'm unable to view the photo
2009 STERLING LT9500 (INOPERABLE) (A63569)
2009 STERLING...
Bobcat 60" Rotary Cutter (A64047)
Bobcat 60" Rotary...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
LIGHT PLANT GENERAC MAGNUM (NONE TITLED) (A63569)
LIGHT PLANT...
2012 Dodge Grand Caravan VAN (A61574)
2012 Dodge Grand...
2021 LIUGONG 925E EXCAVATOR(INOPERABLE) (A63569)
2021 LIUGONG 925E...
