Tree puller in action Bradco Jawz
/ Tree puller in action Bradco Jawz #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So when I purchased my Kubota MX4800 I also bought a Bradco Jaws large model. I have about 30acres of overgrown woodland that was poorly logged in the past. Buying the tree and post puller was a major gamble because I was not sure how well it would work especially not being on a skid steer.
I'm sure a tracked skid steer would work better but I an truly amazed what it and my MX with loaded tires will pull up. Attached is a YouTube link and some pictures.
https://youtu.be/9rQS6wh7ZW8
/ Tree puller in action Bradco Jawz #3
WOW, that is really impressive, what a great implement. I don't think you can beat the MX series of tractors, they are just great tractors, all around. I'm going to take a closer look at that tree puller...
/ Tree puller in action Bradco Jawz #4
What does a tree puller like that cost? Looks like something I might need.
/ Tree puller in action Bradco Jawz #5
Very impressive! That would be perfect for my 40 acres of invasive Buckthorn. Thanks for sharing pics and videos. :thumbsup:
/ Tree puller in action Bradco Jawz #6
Appears to be very well built. The hinge pins are a bit short, but they appear to be large. Are they greasable?
Double jaw is great for clumps of small brush, wider bite.
You'll soon find yourself trying to pull trees that require some rocking back and forth to accomplish. Be very careful about applying compression loads on your tilt cylinders. You'll bend the rams.
Only attachment that I appreciate more than the tree puller is a Grapple. That'll be next on your shopping list!!!! Makes piling those trees a breeze!!! :)
/ Tree puller in action Bradco Jawz #7
Seems like that should go on the 3ph. Then with the grapple up front, Out and stacked in the same session.
/ Tree puller in action Bradco Jawz #9
I wonder at what point a tree puller costs more money than a tree spade? Reason I ask is that birch would seemingly sell for a few hundred bucks from a nursery, not sure if those other things were good trees or just buckthorn/hybrid popular or something else invasive. But that is a lot of good-sized stuff that could be sold!
I wish I had that problem... having farmland means trees are few and far between.
/ Tree puller in action Bradco Jawz #10
BTW... the work done is impressive for that tractor. Is the soil pretty moist?
Don't forget a counterweight when you are doing loader work like that.
/ Tree puller in action Bradco Jawz #12
That I like. :thumbsup:
The hinge pins are greasable but the piston pivots are not. I wish they were because they are also down in the dirt.
Seemed to me that the way i was using it was fairly safe. Do y'all agree? I do hear what you are saying about compression forces. I'm also concerned about twisting force on the jaws. So far, so good.
Yes, I have a very heavy duty Land Pride root grapple that pairs very well.
Its funny that i don't really feel the need for rear ballast with the tree puller (I just keep it close to the ground) but with that heavy grapple... much more stable with 700 pounds of concrete on the back.
Feel free to come pick up a few!
It soil is fairly dry but it's not like they are in hard clay or solid bedrock either.
/ Tree puller in action Bradco Jawz #16
I built my tree puller. I've also got a Grapple. Considered adding 3pt tabs on the puller for that purpose. Just haven't done it because I don't think I want to be that close to the tree being pulled. Not because of danger. Just because of being poked and gouged by tree limbs.
/ Tree puller in action Bradco Jawz #17
Larry, there's a welding shop here locally that builds single cylinder models like mine for $1275. You might do some research in your area. If you can't come up with anything PM me and I'll see if there's a way we can ship you one if interested. They are very well built and braced.
/ Tree puller in action Bradco Jawz #18
I prefer the soil to be a little on the dry side. Let's you shake out a lot of the dirt. In moist or wet soil you go to the brush pile with a lot of dirt. I'm almost always pulling out of clay.
Post some pics!
/ Tree puller in action Bradco Jawz #20
Okay. I didn't want to hijack your thread.
In these pics you can see what I talked about earlier with the double swinging jaws. I don't have near the bite width with just a single swinging jaw.
I started out using mine on a L4400 Kubota. My greatest caution was that I could pull trees that were large enough to upset the tractor if not properly handled. Now I use it on the M9540 and don't worry about that as much.
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
JOHN DEERE PUMPING UNIT (A64278)
JOHN DEERE PUMPING...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
2012 International WorkStar 7500 Gallbreath T/A Rolloff Truck (A64194)
2012 International...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
1973 Glastron V182 Speed Boat (A66408)
1973 Glastron V182...
