Tree puller in action Bradco Jawz
   / Tree puller in action Bradco Jawz #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So when I purchased my Kubota MX4800 I also bought a Bradco Jaws large model. I have about 30acres of overgrown woodland that was poorly logged in the past. Buying the tree and post puller was a major gamble because I was not sure how well it would work especially not being on a skid steer.
I'm sure a tracked skid steer would work better but I an truly amazed what it and my MX with loaded tires will pull up. Attached is a YouTube link and some pictures.
https://youtu.be/9rQS6wh7ZW8
   / Tree puller in action Bradco Jawz #3
WOW, that is really impressive, what a great implement. I don't think you can beat the MX series of tractors, they are just great tractors, all around. I'm going to take a closer look at that tree puller...
   / Tree puller in action Bradco Jawz #4
What does a tree puller like that cost? Looks like something I might need.
   / Tree puller in action Bradco Jawz #5
Very impressive! That would be perfect for my 40 acres of invasive Buckthorn. Thanks for sharing pics and videos. :thumbsup:
   / Tree puller in action Bradco Jawz #6
Appears to be very well built. The hinge pins are a bit short, but they appear to be large. Are they greasable?
Double jaw is great for clumps of small brush, wider bite.
You'll soon find yourself trying to pull trees that require some rocking back and forth to accomplish. Be very careful about applying compression loads on your tilt cylinders. You'll bend the rams.
Only attachment that I appreciate more than the tree puller is a Grapple. That'll be next on your shopping list!!!! Makes piling those trees a breeze!!! :)
   / Tree puller in action Bradco Jawz #7
Seems like that should go on the 3ph. Then with the grapple up front, Out and stacked in the same session.
   / Tree puller in action Bradco Jawz #9
I wonder at what point a tree puller costs more money than a tree spade? Reason I ask is that birch would seemingly sell for a few hundred bucks from a nursery, not sure if those other things were good trees or just buckthorn/hybrid popular or something else invasive. But that is a lot of good-sized stuff that could be sold!
I wish I had that problem... having farmland means trees are few and far between.
   / Tree puller in action Bradco Jawz #10
BTW... the work done is impressive for that tractor. Is the soil pretty moist?
Don't forget a counterweight when you are doing loader work like that.
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51243)
JOHN DEERE 635F...
2015 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A51242)
2015 CATERPILLAR...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2018 Jaguar XE (A50324)
2018 Jaguar XE...
John Deere 960 Culitivator (A50514)
John Deere 960...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
