wood processor build
/ wood processor build #1
triangel
melville sk canada
new holland t1510, 730 case
I started a wood processor build a couple of months ago thought I would share some pictures of the build
I used pipe as this is what I had on hand, I used a 33" blade I found for a reasonable price and made it on a hydraulic pivot . the drive runs through the pivot shaft so it does not affect belt tension 026.jpg024.jpg
/ wood processor build #3
YOU HAVE TREES IN SASKATCHEWAN????????? LOL have fun with the build... keep posting Jim
Yes we have trees and lots of them,damage motor (5).jpgThis is the motor I will be using,it is a 18 hp briggs that I purchased on ebay. Special thanks to the UPS boys for smashing it all up .talked to the guy I bought it from he sent me another one which traveled by tracking it almost 3000 miles all over the US from redding ca to Kentucky and was lost completely by FedEx people. Filed a complaint with ebay and got my money back and got to keep the damaged first motor. straightened all the dents and rewired it and got it working ok.
/ wood processor build #5
You know, it wouldnt take but one decent shipping company to put UPS, FedX, and the USPS out of business. Everything I order now days gets lost, misdirected, returned without a delivery attempt, or just plain damaged beyond use before I ever get it. I orderd a few things from Harbor Freight a few weeks ago. I specified UPS for shipping. HF sent me a tracking number and it was shipped FedX, not UPS. FedX dropped it off at the local US post office for final delivery. Since the shipping address I provided was for home delivery, and I get all my US mail at a post office box, the USPS simply returned the shipment claiming address not found. DUH, I use a PO box because of the USPS was always putting my mail in somebody elses mail box. I got rid of the mail box because I got tired of getting everybodies elses mail. I have UPS and FedX shippments dilivered to my physical address. If UPS and FEDX want my business, I expect the mail to be shipped to my phiscal address. What with the dropping the shipments off for final delevery with the USPS
You are right for sure, I don't know how many people use global shipping on ebay but I will never use it again, the seller I bought this motor from got screwed big time, I waited almost three months and still ended up with a damaged motor but to be fair at no cost so I guess I can't complain to loud but trying to make it right with the shipping companies I could not get to first base with either one. had to work through ebay and the shippers got paid and somebody got the shaft and they were not accountable.
For my log feed I used a simple roller design, pipe inside of pipe with paddles welded on and chain driven. as this moves at a very slow speed and I put grease zerks on I think they will last a long time. I considered using pillow bearings but they were costly and a lot more work, maybe the wrong choice but time will tell.I am using a hydraulic orbit motor to drive this.easter with the boys 027.jpgeaster with the boys 028.jpgeaster with the boys 029.jpgeaster with the boys 030.jpg
I am using a direct drive reduced by pulleys for the saw blade, I have all kinds of pipe so I used it for most of the build , motor mounts,tanks etc, this was supposed to be a low cost machine however the dollars keep moving out at a high rate, wife is starting to give me the look.easter with the boys 024.jpgeaster with the boys 017 (2).jpgI have a helper with me he keeps me going, lots of good advice
/ wood processor build #9
...this was supposed to be a low cost machine however ...
:laughing: I just built one of those low cost machines too :laughing: Mine cost about 2.5X more than I thought it would! It's all worth it in the end. Looking forward to watching it take shape.
Got the motor mounted fine, Last week I picked up all the hydraulic components, pump, reservoir ,splitter ram and valves, that took care of a few dollars. I had a couple of cylinders laying around from leftover farm equipment. started to mount these . I purchased a triple valve body 25 gpm flow and a single valve with a kick off for the splitter. to put these together I had to purchase a power beyond valve for the triple something new to me .dave  and charlie 024.jpgdave  and charlie 025.jpgdave  and charlie 026.jpg
I built a splitter on wheels several years ago and I was going to use it on this machine but by the time I looked it over I realized that I almost had to completely destroy it so I decided to sell it and start with everything new.New I beam 8" and cyl 4"x24" . I will make the splitter slide back and forth so I can move the head out of the way. I wish to be able to cut without splitting smaller logs. easter with the boys 033.jpgeaster with the boys 035.jpgeaster with the boys 036.jpg
/ wood processor build #12
Got the motor mounted fine, Last week I picked up all the hydraulic components, pump, reservoir ,splitter ram and valves, that took care of a few dollars. I had a couple of cylinders laying around from leftover farm equipment. started to mount these . I purchased a triple valve body 25 gpm flow and a single valve with a kick off for the splitter. to put these together I had to purchase a power beyond valve for the triple something new to me .<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422935"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422936"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422937"/>
I used the same tank on my processor. Its way to small, the hydraulics over heat very quickly. I'm using a 15 HP with 28/7 GPM pump.
I'm also concerned about how your powering your saw. If your going with a hydraulic motor, I don't think your engine is big enough and your tank is far too small. Regardless of tank size, you'll need a cooler. If its direct drive, I'm not sure how you're mounting it given the pics so far and I think you'll run into a power issue when the hydraulics are active.
It will be direct drive with a belt just building the clutch belt tightener for it today, You may be right about the reservoir time will tell I guess , it is 10 gallons. the reservoir I had on my splitter I could split for hours and the oil never overheated and it was a lot smaller but again we will see. Hooked up my hydraulics, disaster had the hyd rep from princess auto tell me how to plumb it , He miss informed me and I blew my hydraulic motor apart, I talked to a gentleman on the Hydraulic forum told me what was wrong and I went back to princess auto and told the guy, he said he made a mistake and replaced the motor free of charge. Got the hyd working okay now to get the blade movingdave  and charlie 024.jpg
got the clutch tightener on, appears to be working, just have not figured out how037.jpg to keep it on yet but I am working on it035.jpg036.jpg It is a simple belt tightener with a cable to a lever. would like to have something to hold it on but easy to release if I have to
No , I have been hauling liquid fertilizer for a company to supply farmers for seeding, temporary job just for spring seeding so the project is on hold for now
finally got back to working on this project, took the summer off and went on a trip of a lifetime to Alaska,Yukon, and Northwest Territories. Got back to two months of yard work to clean up on and got started on my processor, I got my grapple built for my tractor loader, works just fine so I managed to fall and limb about 15 cords of white poplar . I did not get my conveyor done yet but I wanted to try my machine out so we just moved it away by hand. I have uploaded two videos to youtube. listed under Little Woody wood processor. One video I just cut the wood and the other I am splitting and cutting it. I made the splitter to slide away so I can do this because we have a furnace which used large pieces of wood 8 to 10 inches in dia so we do not have to split a lot of wood for our use. We cut about 5 cords in one afternoon. No issues with the saw or hydraulics however as Kiotiken advised the motor handled up to 8 inch logs okay but after that I had to use 2 or 3 cuts to regain power to cut through the larger wood. So having said that I am looking a a kubota D622 to replace my 18 hp Briggs and I entertaining comments as to whether or not this is going to be enough power?
/ wood processor build #19
I have to say you were right about the power on my mill, to small, looking for a small kubota diesel if I can find one at the right price
Good luck, I'd love to find one myself.
/ wood processor build #20
I mentioned this to another member looking for a engine and I will just go ahead and pass it along. Around here it seems that there are old ditchwitch's scraped out everywhere. Most of those small machines had 3 cyl dueltz engines. Around 35-45 hp.Some of the bigger machines have 4 and 6 cyl engines. And the engins are air cooled. The dueltz engines have a tag on the side of the block to tell you the hp so you dont have to guess. They run forever and sip fuel. Besides being real good engines, if you can find a complete scrap machine, the engines will have a bell housing for direct pump mount at the rear and a universal joint shaft and pedestal mount for a front pump. The front pump is usually a 2 section pump, not real big flows, but you can combine the flows to run a splitter cylinder or to run a hydraulic chainsaw. Control valves are usually Husco 5000series valves and have power beyond. Theres a lot of parts you can salvage off one of those old machines. Just an ideal and maybe give you something to be on the look out for.
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
Onon E-QD Marine Generator (A64912)
Onon E-QD Marine...
