Put a Rear View Mirror on my Tractor
/ Put a Rear View Mirror on my Tractor #12
I just added one a few weeks ago also. $18 at Sportsman Guide, it's a (new) military surplus vertical truck type mirror with a built in "spot" mirror on the bottom. It is positioned in "detents" with springs and will swing away when something gets a little too close. I have a 4 post canopy and it fit nicely on the front post. A lot more handy than I ever thought it would be for sure.
New U.S. Military Surplus Truck Mirror, Coyote - 592254, Field Gear at Sportsman's Guide
Rusty that swing away feature sounds good. I kept mine inside the tractor envelope but it still looks a little exposed. But then again anything that hits it will probably hit me too so I am hoping it will be a while before I bend it over.
/ Put a Rear View Mirror on my Tractor #14
I thought that mine was cheap @ $18! Can't beat a mirror in the snowbank price!
/ Put a Rear View Mirror on my Tractor #15
Old Square truck mirror mounted on canopy brace- works pretty good
/ Put a Rear View Mirror on my Tractor #16
I put a mirror on my Mule that's mounted with a slow moving vehicle (SMV) bracket. I can take it off and put it on with one hand when driving in the brush. Now that I'm used to having a mirror, I would feel lost without one.
Rear view mirror bracket looks a little better painted. Amazing how you can go to Tractor Supply and buy a can of spray paint and it is a perfect match. I don't know why I wondered if the mirror would be useful. After this short time I would now not want to be without one.
gg
/ Put a Rear View Mirror on my Tractor #18
I'm in the process of devising a way to mount a mirror on my ROPS so I can glance in it to see the edge of the implement behind - usually bush hog, blade or rake. I have to turn around constantly since I have poor peripheral vision and it's a bummer. I'm planning to do it with clamps so I can remove for the frequent occasions when I navigate through my forest areas. Will post if I can figure it out right.
Here's a link to a ROPS mirror mount: Mirror mount on a ROPS support. - OrangeTractorTalks - Everything Kubota
/ Put a Rear View Mirror on my Tractor #19
I bought a couple of cheap golf cart mirrors a while back and finally got around to installing them on the "towers" of my FEL mount.
Clamped the mirrors on temporarily with vice grips to get a good orientation that would allow for adjustment to suit both me and she-who-loves-to-bushhog. Drilled a pair of 1/4" holes in each tower. The "tilt" is a little odd-looking, but that's what was needed with these particular mirror brackets. Note that there's plenty of clearance and easy access inside the tower.
"Squared" out all 4 holes with a small triangle file so that I could use carriage bolts to insure good clearance on the insides. Note: be careful with the placement of the LOWER hole in particular, so that you can fit a carriage bolt head and your fingers in there.
Other than the odd-looking angle of the mount holes/bolts, they work terrific. Total cost, less than $30.
- Jay
/ Put a Rear View Mirror on my Tractor #20
View attachment 429791View attachment 429792
- Jay
JRobyn
Nice clean job...............also inexpensive!
+++++++++++++++++END
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59906)
2018 KAUFMAN 44 FT...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
