Put a Rear View Mirror on my Tractor
   / Put a Rear View Mirror on my Tractor #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
One day last March driving home from the sawmill I spotted a nice truck mirror in the snow bank. Its been laying around in the garage since because I didn't know what to do with it. Today I got the idea to put it on the tractor. I think it will be useful. Especially on the road.
gg
   / Put a Rear View Mirror on my Tractor #2
Yep, a rear view mirror can be very handy. I had a good, strong canopy on my B2710 and mounted a rear view mirror on it.
   / Put a Rear View Mirror on my Tractor #3
Dang good idea...makes operating that much easier.
   / Put a Rear View Mirror on my Tractor #4
Just gas weld that sucker on there huh?.. Looks good.:thumbsup:
   / Put a Rear View Mirror on my Tractor #9
I'm in the process of devising a way to mount a mirror on my ROPS so I can glance in it to see the edge of the implement behind - usually bush hog, blade or rake. I have to turn around constantly since I have poor peripheral vision and it's a bummer. I'm planning to do it with clamps so I can remove for the frequent occasions when I navigate through my forest areas. Will post if I can figure it out right.
   / Put a Rear View Mirror on my Tractor #11
Looks good :thumbsup:
   / Put a Rear View Mirror on my Tractor #12
I just added one a few weeks ago also. $18 at Sportsman Guide, it's a (new) military surplus vertical truck type mirror with a built in "spot" mirror on the bottom. It is positioned in "detents" with springs and will swing away when something gets a little too close. I have a 4 post canopy and it fit nicely on the front post. A lot more handy than I ever thought it would be for sure.
New U.S. Military Surplus Truck Mirror, Coyote - 592254, Field Gear at Sportsman's Guide
Rusty that swing away feature sounds good. I kept mine inside the tractor envelope but it still looks a little exposed. But then again anything that hits it will probably hit me too so I am hoping it will be a while before I bend it over.
   / Put a Rear View Mirror on my Tractor #14
I thought that mine was cheap @ $18! Can't beat a mirror in the snowbank price!
   / Put a Rear View Mirror on my Tractor #15
Old Square truck mirror mounted on canopy brace- works pretty good
   / Put a Rear View Mirror on my Tractor #16
I put a mirror on my Mule that's mounted with a slow moving vehicle (SMV) bracket. I can take it off and put it on with one hand when driving in the brush. Now that I'm used to having a mirror, I would feel lost without one.
Rear view mirror bracket looks a little better painted. Amazing how you can go to Tractor Supply and buy a can of spray paint and it is a perfect match. I don't know why I wondered if the mirror would be useful. After this short time I would now not want to be without one.
gg
   / Put a Rear View Mirror on my Tractor #18
Here's a link to a ROPS mirror mount: Mirror mount on a ROPS support. - OrangeTractorTalks - Everything Kubota
   / Put a Rear View Mirror on my Tractor #19
I bought a couple of cheap golf cart mirrors a while back and finally got around to installing them on the "towers" of my FEL mount.
Clamped the mirrors on temporarily with vice grips to get a good orientation that would allow for adjustment to suit both me and she-who-loves-to-bushhog. Drilled a pair of 1/4" holes in each tower. The "tilt" is a little odd-looking, but that's what was needed with these particular mirror brackets. Note that there's plenty of clearance and easy access inside the tower.
"Squared" out all 4 holes with a small triangle file so that I could use carriage bolts to insure good clearance on the insides. Note: be careful with the placement of the LOWER hole in particular, so that you can fit a carriage bolt head and your fingers in there.
Other than the odd-looking angle of the mount holes/bolts, they work terrific. Total cost, less than $30.
- Jay
   / Put a Rear View Mirror on my Tractor #20
View attachment 429791View attachment 429792
- Jay
JRobyn
Nice clean job...............also inexpensive!
+++++++++++++++++END
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
JLG 2630ES ELECTRIC SCISSOR LIFT (A60429)
JLG 2630ES...
2363 (A60432)
2363 (A60432)
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
iDrive TDS-2010H...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
