Oil Recirculation in closed loop system
/ Oil Recirculation in closed loop system #101
So the fluid returning to tank is determined by the steering control valve position, ie whether turning left or right? This thread has been a great read.
In reference to our Power-Tract, yes. We have an open center steering system with PB, and has priority over any other valve in the circuit. .
There are other hyd steering systems that are closed center, and Load Sensing .
/ Oil Recirculation in closed loop system #102
Orange is pressure, green is tank. Turn the wheel and they reverse. Right? I think I finally get it. :cool2:
423776d1430964448-oil-recirculation-closed-loop-system-steering9-jpg
Now David, tell us which way the the PT is turning in your pictorial.
Front of PT is at bottom of pictorial.
/ Oil Recirculation in closed loop system #103
Am I looking at it from the top or bottom or, should I say, from underneath or above? ;)
/ Oil Recirculation in closed loop system #105
It doesn't matter if you know where the front is.
Will the machine be in a left turn or right turn?
/ Oil Recirculation in closed loop system #107
Well, if your looking at it from above, the right ram is extended, so its turning left. If it just ran over you, and you're looking up at it, the left ram is extended, so its turning right.
/ Oil Recirculation in closed loop system #108
I never ate crow, but my grandma made me eat a bluejay one time.
I have to ask why? :laughing:
My father-in-law said he had a grandfather that would eat sparrows. It wasn't because it was the depression, either. He just liked to trap and eat sparrows. :confused3:
/ Oil Recirculation in closed loop system #110
The question was which way would the machine turn in your pictorial, not the person. But anyway what if the person was laying on his stomach.
Answer would be left turn.
/ Oil Recirculation in closed loop system #111
The question would be moot because he couldn't see the steering rams...
/ Oil Recirculation in closed loop system #112
I didn't say his face was in the ground.
If his face was sideways, he could still see the orientation of the front tub.
He probably could not see anything as he would be crushed with his eyeballs lying on the ground.
How come some of you are trying to make it harder.
It was obvious in the pictorial in post 94 which way the machine would turn with the front at the bottom.
The machine would be in a continuous left circle.
Very few people display pictures from the view of looking up.
Anyway, I hope everyone knows where the fluid is going, and how the cyl are configured.
Black fluid? No one has every said anything similar. Milky colored maybe.
/ Oil Recirculation in closed loop system #116
Left turn, right turn, which way shall I go.
/ Oil Recirculation in closed loop system #118
awesome!
/ Oil Recirculation in closed loop system #119
Okay, so I decided to take a break from the heat and figured I should learn how to make one of these GIF's (I hate MossRoad). Took way too long but now that I have it figured out, I could make a nicer one in much less time.
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
UNUSED JCT HYD AUGER DRIVE AND BITS (A65055)
UNUSED JCT HYD...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2013 23ft Keystone RV 19FBPR T/A Trailer (A64557)
2013 23ft Keystone...
