Princess Auto TIG
/ Princess Auto TIG #2
Without a foot pedal, or remote, it's going to be tough to do aluminum work!
/ Princess Auto TIG
I thought the foot pedal was replaced by a switch on the torch?
Sent from my iPhone 5s 64Gb using TractorByNet
/ Princess Auto TIG #4
In the questions and answers, they say it doesn't come with either.
/ Princess Auto TIG #5
PA has this all messed up!!
There is a 3 page thread on WeldingWeb about this item where a guy has taken it apart to add a pedal and general discussion .Princess auto ac dc tig
For a short time after it launched they offered a footpedal then they took it back off because it "wont work". Its actually internally compatible with a pedal but for some stupid reason PA ordered it with the pedal option disabled! After adding a pedal he can get it to switch on or off but no amp control yet.
Talk on WW is that it appears to be a Parweld XTI202p, which is identical to the TA186. Could be a cheap way to get a 186 if the pedal situation can be figured out.
/ Princess Auto TIG #6
I have an SP-2 programmer on one of my syncrowave welders that allows automated welding, that doesn't use a foot pedal or thumb controled current adjuster.
/ Princess Auto TIG #7
jwmorris, could you please elaborate on this? Sounds interesting...
Terry
/ Princess Auto TIG #9
Eric, don't remember if you were wanting to TIG aluminum, but from the Q&A -
"Are you suggesting that this welder can TIG aluminum? To weld aluminum with DC you need to use mixed helium as the shielding gas. Surely you're not suggesting that qualifies it as "capable to weld aluminum", are you? Aluminum TIG typically requires AC.
KEWL
May 27, 2015
A
This welder can only weld aluminum using MMA (ARC) welding. It cannot TIG weld aluminum."
HTH... Steve
/ Princess Auto TIG
Eric, don't remember if you were wanting to TIG aluminum, but from the Q&A - "Are you suggesting that this welder can TIG aluminum? To weld aluminum with DC you need to use mixed helium as the shielding gas. Surely you're not suggesting that qualifies it as "capable to weld aluminum", are you? Aluminum TIG typically requires AC. KEWL May 27, 2015 A This welder can only weld aluminum using MMA (ARC) welding. It cannot TIG weld aluminum." HTH... Steve
k I got excited for nothing!
You know the old saying-when it's too good to be true...
Oversight on my part
Thanks for the correction
84'' SKID STEER BUCKET (A61572)
84'' SKID STEER...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2022 EZ-GO ELITE...
