Oil Recirculation in closed loop system
/ Oil Recirculation in closed loop system #21
I've added some flow to the chart... hahaha.....
Red is the flow that feeds the steering pump.
Green feeds the FEL valve from the power beyond port on the steering valve.
Orange and Blue are steering.
See how the push on one cylinder is tied to the pull on the other cylinder and vice versa?
The oil never leaves that circuit except for a very little bit in the hoses near the steering valve.
Its like pouring a drink back and forth from glass to glass, the oil just goes back and forth between the cylinders.
423021d1430446956-oil-recirculation-closed-loop-system-hydraulics-jpg
/ Oil Recirculation in closed loop system #23
Your scenario would be true if the volume in the hoses between the cylinder and the valve is greater than the volume of the cylinder.
Ken
/ Oil Recirculation in closed loop system #24
Ken
Nope. As the fluid is pushed out of the extend side of one cylinder, it is sucked into the retract side of the other cylinder. Since the opposite thing is happening on the other sides of the cylinders, the volume is equal.
/ Oil Recirculation in closed loop system #25
I am definitely having a hard time wrapping my head around this. The pump is providing positive pressure, potentially significant positive pressure. So you are saying it does not happen like in the link I sent. Pressure on both sides of the seals are the same if there is no return to the tank. The valve then adds pressure and volume to the "driving" side. The cylinder moves to equate pressures. The "driving" side of the cylinder would have to become lower in pressure than the "relieving" side in order for fluid to go from the relieving side to the driving side. I do not see how that is possible. I can see how you could plumb the return to the suction side of the pump such that the fluid never goes to the tank.
I will have to think about this more. I will blame it on lack of sleep and not from being completely dense.
Ken
/ Oil Recirculation in closed loop system #26
I'm not at a place where I can watch that video w/sound right now. I'll check it out tomorrow.
/ Oil Recirculation in closed loop system #27
A few minor thoughts, for what they are worth.
1) the volumes on either side of the cylinder are not equal. One side has the piston it, the other doesn't. Nor are the cylinder face areas the same.
2) That also means that the effective force differs on the two sides, because the area of each cylinder face is different. (Pressure x area= force, i.e. the pressure difference on the two sides is the force that moves the cylinder). You see cylinders rated for extension/retraction force- this is why. That is also why the extension/retraction speeds are different.
3) At rest, the pressures on both sides are equal. The valve body allows high pressure into one side, and connects the other side to the tank, creating the pressure difference that generates the force that causes the cylinder movement. Basically, opening the valve causes a pressure difference, the cylinder moves to restore the equilibrium, causing the motion that we all benefit from. From a design perspective, you want to add pressure and bleed pressure gradually.
4) Ken's description is true for a compressible fluid, like a gas. For an incompressible fluid, such as hydraulic fluid, to get significant movement, you have to allow fluid in/out of the cylinder sides. In the ideal case, imagine plugging one side of the cylinder. The cylinder won't move no matter how much the pressure changes on the other side. (For real materials- the oil is slightly compressible, and the steel will flex, but only trivially.)
5) If you have a look at hydraulic valve designs, you will see that some cylinders have both sides locked at rest, some have one side connected to the tank, and some connect both sides of the cylinder to each other. (i.e. the "Float" position.) I think of "Float" as a short circuit. (Draft control works by keeping a fixed pressure in the lift side of the cylinder, which is why you don't want to have draft and float engaged at the same time- nothing works, and you are dumping oil from the pressure side to the tank constantly.)
6) If the volume of the hoses is smaller than the volume changes in the cylinders, the oil will exchange. If it isn't, it won't. (Neglecting diffusion.) It is my belief that for the PTs that is true. I have not run the math exactly, but here is a guesstimate;
Assume a 2" cylinder ID, with 10" of movement. That is about 31Cu.in. of oil volume change.
Steering hoses have about a 1/4" hose ID. Dividing that area into 31 cu in, that says that about 640" of hose contains 31 cu. in. of oil.
640" is 53' of hose. So, I would suggest that the oil is probably turning over. From a manufacturing point of view, you would want this to get rid of residual air in a cylinder.
As to why Carl's cylinders were filled with crud... I'll let Carl offer up his thoughts, but it is my impression that his PT is now in a good home, but that prior to arriving in Carl's hands it may have had a hard life, and that may have had something to do with it.
Sorry for the long post. I hope that it helps.
All the best,
Peter
/ Oil Recirculation in closed loop system #28
Peter, what you are saying is what I am saying. I am trying to understand the other description given to see if my understanding is wrong.
Ken
/ Oil Recirculation in closed loop system #29
So here is the diagram I was given. The thing is I don't see really any place for the oil to return on the steering pumps.
I don't feel sitting in the dirt has any real effect on the quality of the oil. But IMO it really looks like they have no way of getting fresh oil without a deliberate draining.
Item #3 is your steering valve.
Item #20 is your steering return to tank.
/ Oil Recirculation in closed loop system #30
The engine turns the aux pto pump.
The aux pto pump feeds the steering valve.
There is a power beyond port on the steering valve.
The power beyond port feeds the FEL/aux pto valve.
The oil flows out of the FEL/aux pto valve back to the tank.
Is that the path you're looking for?
What is the aux PTO pump.
My steering pump feeds the steering, FEL, and aux circuit for a cyl on front attachments.
My PTO pump is independent, and only iused for the PTO.
/ Oil Recirculation in closed loop system #31
Ken and MR: I don't know if this helps, but...
As I see it, the video is correct, although a bit pedantic for my tastes. His simulation of the volume changes due to weight are exaggerated to make the point. For all practical purposes hydraulic oil does not compress, and steel cylinders do not bow outwards. Technically, yes.
On to MR's diagram and the specific case of PTs, at least those with dual steering cylinders; imagine trying to turn. As the diagram illustrates, the two cylinders are connect crossways. If you look at the flow carefully, I think that you will see that when you are trying to steer that oil flows into both cylinders and it flows out of both cylinders to the tank during the operation, but in an "X" fashion, i.e. FR&LR are tied together, and FR&LF are tied, so that to steer, one pair drains to tank, while one pair gets applied oil at high pressure. In detail:
For the steering, the cylinders are tied front one side to back side on theater, i.e. the left push is tied to the right pull and vice versa. To steer, you just swap where you are applying the power. i.e. High pressure in left front half, is tied to high pressure into right rear that combined will cause the left cylinder to contract and the right cylinder to lengthen. (At the same time, oil flows out of the left back half and the front right half to tank.)​
Hopefully, this isn't as clear as mud.
All the best,
Peter
/ Oil Recirculation in closed loop system #32
On our PT425, the variable volume pump drives the tractor. There is a two section PTO pump, one half of which is the main PTO that drives the mowers, etc... the other half of which is the AUX PTO pump that supplies the steering, FEL and AUX PTO. The AUX PTO is the smaller connectors that operate the quick attach circuit and the lever is by the operator's knee.
/ Oil Recirculation in closed loop system #33
Ken
If it was one cylinder you'd be correct. However, the dual cylinders in the steering circuit aren't hooked up like the video you posted. Go back and look at your hydraulic schematic. The hoses are cross-fed between the two steering cylinders. In essence, there are two steering circuits. Left and Right. When left has pressure, the right just sloshes the fluid from the top of one cylinder to the bottom of the other. When right has pressure, the left does the sloshing. (its not actual sloshing of course, but just movement under less pressure than the other direction). That's why the fluid in your left and right circuits never leaves the circuits. It just travels back and forth between the cylinders. Only a very, very small amount is exchanged near the steering valve. And I mean a very small amount.... only any amount that could leak by the piston in one of the cylinders would force fluid out of the left or right circuit and would then be made up.
/ Oil Recirculation in closed loop system #34
All the best,
Peter
I concur.... (like I'm some kind of authority! hahahhahaaa). :)
/ Oil Recirculation in closed loop system #35
Moss, In your description, what provides the driving force? It has to be the pump. That means there has to be flow back to the pump or to the pump via the tank. If it just goes back to the pump, then you can have a basically closed circuit with little exchange except due to leakage/makeup. But the flow can not be from one cylinder into another cylinder directly because you would have a lower pressure trying to outfight a higher pressure. As an aside, you would actually get some mixing though even with a 200 psi differential which I find amazing - we have pressurized systems that are O2 free that will get contaminated with minute traces of O2 from the air when there is the most minuscule of a leak. These systems are so sensitive to O2 that we can tell when it happens.
Ken
/ Oil Recirculation in closed loop system #36
Ken
The steering pump is always pumping. It never stops. It can't stop. So, when you are not moving the steering wheel, or operating the FEL or aux PTO, the full flow of the pump goes straight through the steering valve and back to the tank.
If you turn the steering wheel, the pressure becomes available to the steering rams. That doesn't mean much (if any) of the flow is going to the rams at all, just the pressure.
/ Oil Recirculation in closed loop system #37
Take a look at this circuit. It is two rams for a lift circuit. In this example, the tops of both cylinders are tied together, as are the bottoms. If you push the rams out, the fluid fills the bottoms of both cylinders and forces the fluid out of the tops of both cylinders. Most of the fluid exiting the tops will go back to the tank (except what stays in the hoses as it reaches the end of travel). The reverse happens when you lower the cylinders. Fluid is exchanged in this example, and I think this is what you are thinking of.
CASE-586E-Hydraulics-MAST-TILT-CYLINDER-HYDRAULIC-CIRCUIT-MODELS-WITH-DUAL-LIFT-CYLINDERS-W-31-D.gif
423132d1430541040-oil-recirculation-closed-loop-system-case-586e-hydraulics-mast-tilt
/ Oil Recirculation in closed loop system #38
So that is not a dual ram steering circuit. Its a dual ram lifting circuit.
/ Oil Recirculation in closed loop system #39
I am definitely thinking in terms of the FEL circuit when I am thinking about this. But it seems to me that the only difference in the steering circuit is that opposite ends of the cylinders are tied together instead of the same ends. You have movement of the cylinder rams which means you must have flow, not just pressure. I really can not see how it could be any other way.
Ken
/ Oil Recirculation in closed loop system #40
I don't agree.
The steering is available at all times, and has priority.
The FEL get the PB fluid from the steering valve.
The fluid is flowing through the steering valve through the FEL, then to tank.
You always have volume in GPM, the hyd components develop the pressure.
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
6 Band Wood Barrel (A64557)
6 Band Wood Barrel...
KING 22 BLADE DISC HARROW, 3PT (A64278)
KING 22 BLADE DISC...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
