Brake Controller adjustment
/ Brake Controller adjustment #1
joe04785
Maine
XR3037
I got a 18ft 10000lbs car hauler that I use to haul my tractor around. I got a question on how the brake controller should be set when empty and should be set when loaded? I have a Curt discovery brake controller and by the instructions the settings are too tight for my trailer. Any advice on settings would be great. Thanks.
/ Brake Controller adjustment #2
AS long as the brakes aren't locking up when empty you should be good. Some people like to try a couple test stops by applying more braking power from the controller, once they hit lockup, they back it off a touch. As far as loaded, I like to be able to apply the brakes and not feel the trailer pushing or pulling the truck. I have never really been able to set and forget the brakes on a trailer, its a small process every time I go to make sure they are setup each time. To each their own I guess!
/ Brake Controller adjustment #3
I tend to turn the gain all the way down when unloaded, almost all the way up (probably to 90%) when I'm loaded to capacity, and somewhere in between for in-between sized loads. I still get adequate braking out of my old school Reese controller at the lowest setting to keep all my unloaded trailers behind me under hard braking, and at 90% all my heavy loads get stopped like there isn't much load at all.. I get about 30-35k miles out of a standard set of brakes on the truck (average for our terrain), and not sure how many on the trailer brakes, I've got about 8k miles on my dump trailer and it just passed inspection. I was told the pads were still over 50%...
/ Brake Controller adjustment #4
I set it till it just locks up around 20mph then back it off a touch.
Chris
/ Brake Controller adjustment #5
What Chris does is exactly what the instructions that came with my brake controller say to do. I have 3 levels of boost on mine. I leave at the lowest when empty or hauling less then 1,000 lbs, bump it up one for loads between 1,000 and 3,000 lbs, and turn it to high when over 3,000lbs (with a 7k trailer behind a Tundra). I have plenty of stopping power woot hour locking up.
Will
/ Brake Controller adjustment #6
I hit the brakes hard from 30 each time I haul. Turn it up till I can tell the trailer is stopping us or see the trailer brakes lock up, then back off and check again. I also watch the tractor and whatever I have on it at the same time to be sure nothing is moving.
Want to scare a new low spot in your seat? Try it going backwards......
Thanks for all the great advice guys.
/ Brake Controller adjustment #9
I use a MaxBrake brake controller. It requires no setup other than the initial calibration and that is done without a trailer. It has a "gain" that is not really a gain control. It only controls "when" the trailer brakes come on. I have mine set to apply the trailer brakes just slightly before the truck brakes take hold. It works, with out adjustment, whether the trailer is empty or loaded. It is controlled by a pressure sender that is placed inline at the brake master cylinder. I got rid of several controllers because I got tired of having to adjust the controller every time I loaded or emptied my trailer. the newer trucks with the towing packages are equipped with the same type controller.
the pro's,
all of the aforementioned.
Con's
Expensive.
/ Brake Controller adjustment #10
I use a MaxBrake brake controller. It requires no setup other than the initial calibration and that is done without a trailer. It has a "gain" that is not really a gain control. It only controls "when" the trailer brakes come on. I have mine set to apply the trailer brakes just slightly before the truck brakes take hold. It works, with out adjustment, whether the trailer is empty or loaded. It is controlled by a pressure sender that is placed inline at the brake master cylinder. I got rid of several controllers because I got tired of having to adjust the controller every time I loaded or emptied my trailer. the newer trucks with the towing packages are equipped with the same type controller. the pro's, all of the aforementioned. Con's Expensive.
Max Brake is one of my favorite. I have installed about a dozen of them but they are now out of business. They work just like the Ford Factory Controllers. I have the factory units in my 2006 F350 and 2012 F150 and they blow way any under the dash box.
Chris
/ Brake Controller adjustment #11
CRAP!
Max brake gone!! I have one still in the box but the fittings are wrong for the last truck I have that I was going to put it on. A fella bought it for his Dodge but sold the truck before he installed the controller. I got if for a song. Well, I bet this boy can figure it out. At least I have the controller.
/ Brake Controller adjustment #12
CRAP! Max brake gone!! I have one still in the box but the fittings are wrong for the last truck I have that I was going to put it on. A fella bought it for his Dodge but sold the truck before he installed the controller. I got if for a song. Well, I bet this boy can figure it out. At least I have the controller.
The only thing truck specific was the threads on the adapter for the pressure switch. Shouldn't be too hard to make work.
Chris
/ Brake Controller adjustment #13
CRAP!
Follow this link to the website and call Dutch and Diana. They were distributors for MaxBrake, but still are available for help. They may be able to fix you up with the correct tee for the brake line, or will be able to get you a part number so you can get one. They are great people and their customer service is second to none.
Home {index} 941-416-0918 10 to 10 7 days a week plugitright@mail.com
/ Brake Controller adjustment #14
Chris
I'll second Chris on this, My 06 F350 has the factory controller and it is GREAT! Coupled with tow / haul mode it makes it a joy to tow my fifth wheel.....
/ Brake Controller adjustment #15
the pro's,
Con's
Expensive.
I have a factory controller in my f150 and must adjust the gain based on the load on the trailer. How does the maxbrake work with an empty trailer without smoking the tires during a hard stop? I'm confused on how that would work. I would think a high hydraulic pressure on the tow vehicle would equal a high voltage going to the brakes but I must be missing some logic.
I set mine squeezing the lever all the way over while driving about 20 mph and adjusting right to the point of not skidding the tires. Most electric drum trailer brakes require full gain setting with a loaded trailer as they aren't powerful enough to lock up the tires.
/ Brake Controller adjustment #16
Eh, I just use the front end loader to hook into my Honda Fit, strap her down and go. I read on the internets that it still lubed the stuff.
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
1989 Heil MC 307 Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1989 Heil MC 307...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
