Flat face hyd. coupling "pressure release" tool
/ Flat face hyd. coupling "pressure release" tool #21
Hey, that'd be cool!
I was figuring on "manifolding" all connections together with a valve (or a vent, for that matter).
I'm tired of fighting that stupid thing!
/ Flat face hyd. coupling "pressure release" tool #22
Email sent ;)
/ Flat face hyd. coupling "pressure release" tool #23
Email returned. Thanks!
For the sake of the discussion, this is what I had in mind.
I am certainly not locked into this design, but it'd work. Maybe there is a less fitting intensive design. I've seen those air manifolds (http://ecx.images-amazon.com/images/I/51avnKHPgDL._SX342_.jpg) but it's a 3-up with a spot for a valve, not a 4-up. Plus I dunno about room for the other fitting half.
This is 3/8 fittings and nipples, probably just from Home Depot. 1" nipples appear to be plenty large and give room for the mating fittings.
/ Flat face hyd. coupling "pressure release" tool #24
Hope you are not using hardware designed for natural gas pressure and water pressure for 2500 PSI?
/ Flat face hyd. coupling "pressure release" tool #25
This manifold is not built to hold pressure...but to rather relieve or keep pressure from building in the first place. It's a "antipressure" device :)
/ Flat face hyd. coupling "pressure release" tool #26
Please forget that I posted that!
/ Flat face hyd. coupling "pressure release" tool #27
An interesting solution.. I remember an older fellow who added a tee with a high pressure tap . It was plumbed with a small line to the tank . He found that hooking up with pressure was too much for his strength .. He would crack the tap and excess pressure was bled off ...
/ Flat face hyd. coupling "pressure release" tool #28
I have fought this issue since I first added my 3rd function 5 yrs ago or so on my first tractor (don't recall exactly when...) Everyone always chimes in with the same advice, which is apparently a common issue: The implement heated up and built pressure in the sun, or the tractor did, etc. This is not the case. I could disconnect the grapple on my 3rd function, then immediately try to reconnect it (using all proper procedures for pressure release, etc) and you could not do it. No sitting in the sun, or months to have pressures change, I mean within seconds. I finally cried uncle and built a reliever for myself. This is a few pipe fittings and a male coupler on one end, and a female coupler on the other end. I attached each coupler to a 3" or so pipe, and then put a 4-way "tee" fitting in the middle with a couple short pipes sticking out as handles (I left the handle out on one, and it worked fine too, FYI). NOTE - the handles are not capped, so this is open to the atmosphere. Push this onto any fitting that is fighting you and you will spit a little fluid into the pipe and it will now go together. I stuff a paper towel in there to soak up the fluid, and drain on occasion. This has been true now for 2 different tractors, so it is not me going insane, it is not the tractor, it is not the temperature differential, etc. These things just allow pressure to remain that will not allow you to re-connect without something to relieve it.
/ Flat face hyd. coupling "pressure release" tool #29
I fought mine for years and finally realized that instead of spending all that time releasing the pressure and getting them either connected or un connected, it would be faster and easier to just take them off and screw the hoses together when connecting them, and then unscrew them when I take off my grapple. I then screw plugs into the ends of the lines. Easy, fast and simple.
Eddie
/ Flat face hyd. coupling "pressure release" tool #30
Interesting comments.
I hope what I'm doing actually solves my issues.
/ Flat face hyd. coupling "pressure release" tool #32
I have that connector on an Avant 528. It works with pressure in the lines, motor running, you can't hook it up backwards.
/ Flat face hyd. coupling "pressure release" tool #33
What is it?
I mean, I know it's a bulkhead with a handle that makes it assemble, but what make/model/type/etc.
Details man, details!
I still have hopes for my manifold, but that thing certainly is cool.
/ Flat face hyd. coupling "pressure release" tool #34
What is it?
I don't know where you can get it. It's made by a company called "faster" it's Italian. If you find a source let me know, I have not tried to find it.
/ Flat face hyd. coupling "pressure release" tool #37
That's what this thread started out as, till I accidentally hijacked it completely.
Well, pliers to depress the seal in the bottom, to release the pressure.
Hopefully I won't need one now, but if I do, A cheap c-clamp will have to be sacrificed. I'm tired of beating on it.
/ Flat face hyd. coupling "pressure release" tool #38
What is it?
They are made by Faster Hydraulics, and cost $600+. John Deere uses them on some of thier larger machines.
MULTIFASTER
/ Flat face hyd. coupling "pressure release" tool #39
MULTIFASTER
I have two implements that use it. I'm thinking of making one set of lines quick disconnect at the implement and then using that set of lines to power a couple other things, a grapple and also a home made log splitter. It'll save some $$.
/ Flat face hyd. coupling "pressure release" tool #40
Sad to say I'd be ponying up to maintain the awesomeness. Do you have a supplier that you get 'em from?
Need to go in my "as-if" tractor bookmark folder....
2009 Blue Bird All American/ All Canadian School Bus (A61573)
2009 Blue Bird All...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
2017 Forest River Rockwood Freedom Camping S/A Trailer (A61574)
2017 Forest River...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
Adams 8 Ton Blender (A63688)
Adams 8 Ton...
