4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,222
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Once you get better at releasing the couplers properly there’s a lot less trouble getting them back on. You close the grapple all the way, turn the tractor off, turn the key back on and cycle the grapple buttons numerous times which releases the pressure before uncoupling. Repeat the releasing steps before attempting to recouple. The problem that’s hard to avoid is heat expansion in the grapple. If the fluid is at operational temperature when you unhook that doesn’t usually happen. If that’s not feasible at least put the implement in the shade.
