Flat face hyd. coupling "pressure release" tool
/ Flat face hyd. coupling "pressure release" tool #1
Rustyiron
Super Member
Lakes Region, Maine
M 9540 Kubota
Threw these together during shop time with all the recent snow. It seems lately that all my hyd. attachments are needing me to "crack a line" to release about a tsp. of fluid to connect them. Very frustrating, and yes I know how to release the pressure before you disconnect. I'm convinced that it only takes a few degrees of temp. difference to expand the fluid and create enough pressure to make it impossible to do. Pretty simple, for the male end I just made a slot to hold the fitting in one of the recessed groove and use a bolt to screw into the middle part to release the pressure. The female side I found an old socket that fit (with a little grinding) into the proper "ring" on the face and plunger that is hand activated. They seem to work well so far.:D
/ Flat face hyd. coupling "pressure release" tool #2
Rusty,
A word of caution on the flat face QD's. Some of these have an O-ring seal that can pop out of it's groove if the mating connector is not there to hold it in place. I don't know how much movement is required for this to happen but when it does the QD can not be used until that seal is replaced or reinstalled in it's groove.
/ Flat face hyd. coupling "pressure release" tool #3
Rusty,
Been there, ruined that, with my own depressurizer.
Hey thanks for the heads up. Have you guy's figured some other way? Is this on the female side or both? It (so far) don't seem to bother the Parker QD's
/ Flat face hyd. coupling "pressure release" tool #5
Not sure how far they have to be pushed in to expose the seal. Best suggestion to be take one that you has no pressure on it and push the seat in slowly until you can see the seal. My experience was with Snap-tite and Foster, possibly Parker traps the seal a little differently to reduce this risk of the seal extruding.
I believe in my case it was typically the female half that caused the most problems.
/ Flat face hyd. coupling "pressure release" tool #6
I think so.
My theory is that the on the flat faced coupler systems, compressing the moveable component on the tractor's flat faced coupling tries to displace hydraulic fluid trapped between the joystick controlled valve and that flat faced coupler. And since these FFC's seal so well, especially when new, there is no place for the fluid to flow, thus the resistance of that moveable FFC component.
To test this theory, I've held the joystick controlled valve in the open position while coupling an attachment and the coupling is quite easy. Problem is you are at the front of the tractor and the joystick is out of reach. A two person job or judicious use of a C-clamp or bunge cord to hold the valve in its open position.
Should have mentioned that the engine was off but the ignition switch was in the intermediate position.
/ Flat face hyd. coupling "pressure release" tool #7
I know an easy way to avoid pressure on hoses. On each tool equipped with hydraulic devises, you simply made a small sealed box. Above this one, you fit couplings. So, when you park your tool, you disconnect your 2 hoses from the tractor, and fit them onto the box. The oil will be drained inside the box realeasing the pressure all the time even if you don't use the tool for many days. When the box is full, drain it.
Well the blue tool for the male ff coupler is all I need to use. I just put it on the attachment (male) & then on the machine (male). This has been working well and has not given the coupler any troubles. I might just be imagining it, but the male fitting seems pretty simple vs. the f/m fitting and the previous advice about possibly disturbing an o ring.
/ Flat face hyd. coupling "pressure release" tool #9
I was thinking of buying extra couplers and just putting a 1/2" NOT ball valve on them Plug them into the Attachment as soon as I disconnect it. Then open the ball valve just before I go to reuse that attachment. That should keep Fluid from dripping and draining all the time it's not in use yet depressurize it to do the hookup.
These guys make a tool to push against the pressure but not available in the USA QUICK-ON
/ Flat face hyd. coupling "pressure release" tool #10
I know this is an old thread, but I'm curious what people are doing these days.
I literally have to BEAT my fittings on after my loader sits for the winter. I de-pressurize everything before disconnecting, etc. too. It just settles, period.
I have a 2013 L3940. I'd love a tool for the fittings like the quick-on. Or maybe modifying a C-clamp. Or maybe a "X" fitting some 90s, and some fittings makes sense. Just create a manifold where all pressures can equalize. This assumes I can attach the connectors to it within a few minutes of disconnecting them. I almost suspect that I'd have a problem with that, but maybe not. What kind/size of fittings do I have?
Am I the only one with this problem these days? I don't see how I can be.......
/ Flat face hyd. coupling "pressure release" tool #11
Usually a quick rap of the fitting against the loader arm or a flat metal surface is all that is needed to release the pressure, just be handy with a shop towel to clean up the puke.
/ Flat face hyd. coupling "pressure release" tool #12
You must have different fittings than me.
Mine have a nipple that is recessed about an inch into the fitting.
I pull the collar, put it on the mate, and push with all my might. Eventually I resort to the 7/8" wrench and a friggin hammer. Replace pushing with hammering on the wrench. I get some oil in the connector with each hit. Eventually it must be enough that the fitting goes on. Only half of the fittings are a problem, so that makes sense.
When I put on the snow blower/frame, I have no issues.
/ Flat face hyd. coupling "pressure release" tool #13
Well the QD on the implements usually have a protruding nipple. The flat face couples the male end a corner can usually be had to get the pressure released. The female side is a bit trickier. My problem is usually ice build up from the couplers being outside. I have gotten in the habit of hooking my flat face couplers together when I am done using them to keep them clean, maybe that would work for you?
/ Flat face hyd. coupling "pressure release" tool #14
I have 4 female connectors on the loader, and 4 male connectors on a bracket on the tractor. So, nope.
This is on the tractor......
Can't find a pic of the mate.
I'd love to know size/style/mfg part numbers if anyone knew them, too.
/ Flat face hyd. coupling "pressure release" tool #15
I did what I mentioned in my post (post #9 I think) I made a pressure release with extra connectors. The problem isn't with the tractor it's with the implement. If you try to reconnect when the temperature is hotter than when you disconnected.... It builds pressure in the lines. It's a problem with the 'new' Flush Face connectors (ISO16028). They are environmentally friendly, just not User friendly.
/ Flat face hyd. coupling "pressure release" tool #16
I like that.... I bet you're right, I bet it's temperature more than the loader settling. That makes perfect sense.
What kind of connectors do I have on my L3940? I can't seem to figure it out.
On the up side, i only need to buy the "cheap" half of the connector....
/ Flat face hyd. coupling "pressure release" tool #17
/ Flat face hyd. coupling "pressure release" tool #18
oooo, awesome. Do the 3/8" use a 7/8" wrench? I *think* that's the size I had to use......
I didn't even know you guys did more than hooks.
I also like how Amazon is 2x your price (and yours is comparable to others, so amazon is stupid).
So maybe $35 solves my problem. Giddyup.
You'll be getting an order, small as it might be..
I wonder if there is reason to buy extra fittings. Maybe a spare set.....
/ Flat face hyd. coupling "pressure release" tool #19
Well, I ordered 'em.
I'll get Ts and nipples and a valve locally.
Then next year at this time, I'll know if it worked. :thumbsup:
/ Flat face hyd. coupling "pressure release" tool #20
Thanks for the order! I'll check on a proper Tee for you to eliminate the nipples.
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61574)
2012 23ft...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
