Split-dovetail car hauler trailer
/ Split-dovetail car hauler trailer #201
Lookin gooder! :D :thumbsup:
/ Split-dovetail car hauler trailer #203
By the time you get done your gonna need 7000lb axles:stirthepot:
/ Split-dovetail car hauler trailer #204
Looking good! Your definitely making it heavy duty.
Cleaning up the welds on the other fender.
I used my mag-drill to hold the inner brace in place while I tacked it, worked like a charm. I had a few good welds and a few that....well..wasn't.
Fenders done (thank God). They were a pita to get them to look this good. They are not perfect (not my best work) but they will do. A few have suggested that I put a brace on the front and back of each fender and I think I probably will. Here's a few pics of my version of drive-over fenders.....After much thought and in order to save weight, I removed the mag after they were welded on, they just look better without it....
/ Split-dovetail car hauler trailer #209
You do some very nice work! :thumbsup:
Braces for the fenders. I went ahead and drilled and tapped for running lights before I welded them on. I kinda liked the look better without them, but I know they'll make them a lot stronger.
Welding upside down is always a challenge for me.
I also drilled and tapped for a side marker light.
Here's a few pics of how they'll look with the running lights mounted.
/ Split-dovetail car hauler trailer #216
Loving it. :thumbsup:
/ Split-dovetail car hauler trailer #218
I believe you did a fantastic job!
I decided to change the tongue jack for a heavier one sense I sometimes like to unhitch the trailer with it still loaded. I'm going to install an 8000lb side wind, drop-leg style jack. Here's a 3/8" plate I made to hold the jack, it has a 4" channel gusset under the plate. Hope to get the jack welded on later tonight.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2016 Autocar Xpert New Way 13RLC 13yd Rear Loader Garbage Truck (A59230)
2016 Autocar Xpert...
2024 GMC Seirra Elevation 4X4 (A60352)
2024 GMC Seirra...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
