Quick Hitches Clevis style bushings for Quick Hitch
/ Clevis style bushings for Quick Hitch #1
Raincoast
Powell River BC
Kioti ds4510 / kb2485 backhoe / KL401 loader
Hi Folks;
A couple of weeks ago, we drove across the line to Lynden WA to buy our new Woods BSM 72 box blade.
VERY NICE piece of equipment. Worth the long drive (almost 200 miles & 4 ferries for the return trip) and the extra bucks, after seeing the cheesy stuff that was available locally.
While at the dealership, I asked if they could supply straight QH bushings to fit the clevis style lower attach points.
Seems no-one had ever asked for them before, so I bought a pair of the standard step bushings to cut down to size.
With more & more attachments being built with clevis lower attach lugs, it seems like someone out there should be making simple bushings to fit. Seems a waste to build a stepped bushing, drill cross holes in it & supply roll pins all so I can hack off the fat end & toss all the extra bits in the scrap bucket. Sheesh!
Anyone out there know where I could get some straight bushings to do the job?
On the bright side, the BB works beautifully. I levelled out the driveway on Monday & it was a breeze. No drama at all... Just a smooth surface after a few passes. I crawled along at the lowest speed possible & kept my hand on the 3 point lever. Very small adjustments & slow speed did the trick. I know it's gonna be even easier when Brian sends me my hyd. top link.
Can hardly wait till everything dries out enough to start levelling our small pasture!
My only complaint (if you can call it that) is how awkward it is to remove the R pins for the 2 outer rippers. Fixed that in a hurry by looping a knotted piece of cord through the R pins. A quick tug on the cord & the pin's out. No sweat & no tools required. I even put cord on the draw bar pins while I was at it. They are really hard to reach with the backhoe installed.
Cheers all. Dan
/ Clevis style bushings for Quick Hitch #2
Farm supply stores around here have straight bushings for a few dollars each. You generally need two sets, Cat 1 to Cat 2, then Cat 2 to Cat 3. They probably won't be an exact fit lengthwise, but should be close enough. They are basically just sleeves.
/ Clevis style bushings for Quick Hitch #3
That is what I use. I use them on some implements that do not have a clevis hitch too.
/ Clevis style bushings for Quick Hitch #4
I used bushings as well for my Clevis style implements.
I didn't have any on my rear blade and had a REALLy lot of excess movement.
I put a cat 1-2 and the cat 2-3 bushing on (one inside the other) and this really tightened up the slop in the fit to the quick hitch.
/ Clevis style bushings for Quick Hitch #5
Landpride makes them for their qh, its what I use. My dealer has to order them, they come in a few different lengths and they run about 10 bucks a piece.
/ Clevis style bushings for Quick Hitch #6
We use the same as Piston, tractor supply had what I needed to step up the pin to what the QH needs. Not a big deal..
Thanks guys... I checked out the Land Pride site & their bushings look just right. Luckily, I have a dealer nearby.
/ Clevis style bushings for Quick Hitch #9
This is a message that I wrote to someone inquiring about where to get the bushings... I thought it might be helpful to this thread as well.
As far as where to get the bushings, you can find them either online, or at Tractor Supply. I purchased online at Agrisupply.
There are two types of quick hitch bushings. If you have a clevis style hookup on your implement, you can use the cheaper bushings that are basically just "sleeves" that step up the size of your cat 1 pin, to cat 2, and then cat 3. So it's actually two sleeves you would need, to go from cat 1 to 3.
Here is the lift arm bushing to go from cat 1 to 2:
Lift Arm Bushing, 1-1/8" x 7/8" x 1-3/4" | Agri Supply, 11959
And then the larger bushing that slides over the smaller bushing to bring it up to cat 3 standards:
Conv Bush, Lift Arm Cat 2 To 3
The other style is used when you have the more standard hookup on your implement, like most lighter duty implements, where it isn't the clevis style but rather a 'pin' coming out that each lift arm slides over, from the outside of the implement.
For that style, you'd use this type of quick hitch bushing... (which unfortunately are much more expensive)
CountyLineョ Quick Hitch Bushing Kit, Cat 1 - Tractor Supply Co.
For the top link, you buy top link bushing kits:
1-2: Conversion Bushing for Toplink Cat 1 and 2
2-3: Conversion Bushing For Toplink Cat 2 To 3
Here is some more information on the quick hitch that I purchased:
http://www.landpride.com/products/87/qh15-series-quick-hitches
As for the "slop", it really isn't that much if you only use the cat 2 bushings, but if you don't use any bushings and have the cat 1 pin size in the quick hitch hooks, then to me, there is way too much slop in the implements.
Let me know if you have any questions.
-Matt
(For more detailed info on the bushings, check post number 83 on this thread: http://www.tractorbynet.com/forums/attachments/146479-land-pride-quick-hitch.html )
Thanks Piston!
Just what I needed. I was having trouble finding the top link bushing as well. Great to see that included in your post. They will probably cost less than from our local guy, too.
Cheers! Dan
/ Clevis style bushings for Quick Hitch #11
The simple, inexpensive bushings work fine on both types of pin. The implement never touches the retaining pin.
Bruce
/ Clevis style bushings for Quick Hitch #13
What I've never understood is why do we have to get 2 bushings to go from CAT-1 to CAT-3. Why in the world isn't there a CAT-1 to CAT-3 in a single bushing that isn't the even more expensive stepped kind. I looked up tubing and couldn't find any the right size. Wasn't interested in trying to machine it.
Also, FWIW at TSC by me, each bushing is $3. (so 3x6 is $18). At Agrisupply a complete set would be $5.64. Not counting taxes on tsc or shipping on agrisupply.
/ Clevis style bushings for Quick Hitch #14
There are bushings that go from Cat 1 to Cat 3 like you describe. A set came with my imatch. They are probably expensive through deere though.
/ Clevis style bushings for Quick Hitch #15
I'm going to split a pair and drill a hole through them and tack them into the lower lugs to step it down to class 1 to save buying several sets
/ Clevis style bushings for Quick Hitch #16
I have a few sets of these bushings that go from cat 1 to 3 in one piece but could not remember where they came from. Like the others I haven't seen them available off the shelf but would buy a hand full of upper and lower plain bushings.
/ Clevis style bushings for Quick Hitch #17
I got my cat 1 to cat 3 adapters from Land Pride. The adapters for the lower pin are in the Quick Hitch parts manual, but the adapters for the top pin are in individual implement parts manuals, for some reason. I also got some adapters for the top link hook from Woods.
/ Clevis style bushings for Quick Hitch #18
Dug up this old thread and looking for a dozen of the cat 1 to cat 3 adaptor bushings like this. Anybody have a handle on where to get them?
Looking for the simple bushings for clevis style hitches. Do not want to use two bushings for this.
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
