Linear actuator for power SSQA?
/ Linear actuator for power SSQA? #61
Yeah, this is a Kubota-only SSQA mod. What can I say, it's what I have, and what I care about...
I think a detailed how-to would interest quite a few people. Or maybe not and it'll just be for me. Whatever.....
I'm looking at shoulder-bolts or studs threaded into the levers, and that's the only mounting, one at each end. We'll see if that works when I get farther along with the details. $250 for a drop in actuator vs. $150 actuator plus 1?,2?,3? custom "machined" pieces seems (on the surface) to be a no-brainer, at least to me. To each their own.
/ Linear actuator for power SSQA? #62
Yes our DK series (and probably the NX series too) Just have one Handle. Hopefully this will show up in these pictures. I can't tell much from the "thumbnail" pictures.
Wow. I had the 400lbs one in my Amazon cart just waiting to go on my next Amazon order. I ended up actually using the tractor a bit today moving a few things around & can't believe how handy this mod is. The really surprising thing to me is the fact the cycle speed isn't that relevant to using the thing. I flip the switch 30 seconds before I go to dump the implement & it's ready to go when I get there. Latch time is similarly irelevant. Grab the impliment, tilt the SSQA carrier back so it tightens up a bit, hit the switch & go. By the time I'm barely even turned around, much less where I'm going it's latched (or at least as latched as 4" is going to get).
Really happy with how this mod is working out.
Also the 4" while clearly not enough actually gets me 90% of the way latched every time so far. Safe enough for puttering around for now until I get the 6".
I need to put some more thought into what actuator I'm going to get now. I had more or less decided to upgrade, but am not so sure now. The $60 Ebay special seems like it might very well be up to the task (6", not my current 4").
/ Linear actuator for power SSQA? #64
Glad it is working so well. :thumbsup:
But I thought you needed 7.5 inches to get over center?
7.5" of travel from levers (not pins) fully up to levers fully down, including them going way over center.
There is a little over 5" of travel between pins fully up & pins fully down, the remaining couple of inches is things throwing over center to latch. As the actuator takes care of preventing the pins from coming loose, the extra distance is moot for my purposes.
At any rate I think I'll have to modify my current brackets (or make new ones) so the bracket will hit the loader arm & bottom out (say 1/2" of free play before both brackets bottom out). That way the actuator will be forced to push both pins down rather than one down & one half way. It doesn't seem to be an issue with the 4" actuator, so I doubt it would be an issue with a 6", but better to be safe than sorry.
/ Linear actuator for power SSQA? #66
View attachment 418630View attachment 418631View attachment 418632View attachment 418633
James, I love looking at pictures posted on here. I usually get side tracked and forget the purpose of the picture because of some detail I see that has nothing to do with the subject. Happened with yours. I like the bungee cord holding your hoses up out of the way!!!! When I'm running flat on the ground my Grapple hoses are lightly dragging the ground. Goin to town today to find a cord to hang mine with!!! :)
/ Linear actuator for power SSQA? #67
Sounds great!!! I wasn't worried about the speed of it all because of what you just described.
Still not sure I heard yet how the actuator is protected if it can't complete the stroke?? Is it thermal protected or in some way kept from just sitting there burning up the motor trying to move??
/ Linear actuator for power SSQA? #68
Yep, in mid span of the hoses, I put a couple of black tie-wraps, and hooked one end of a cheap bungie cord in the tie-wrap, and closed the eye of the bungie with a pair of pliers so it stays with the grapple hoses. Then hook the other bungie hook over a fitting and you are all set. When the grapple comes off, the free end of the bungie hooks to the grapple, and helps keep the hoses up off of the ground too! I like it better than the expensive spring idea. Cost about .50 cents
/ Linear actuator for power SSQA? #69
Is there any reason why it has to run a full stroke? I have zero experience with them but I can't imagine that they are built in such a way they can't stop mid stoke when the power is cut, nor is it designed to have constant power. Switch it with a spring loaded on-off-on then it only runs when you say so.
/ Linear actuator for power SSQA? #70
Great idea. And would probably simply break without any hose damage when you forget to unhook it from the tractor when dropping the Grapple. Not that I'd ever do that.....
/ Linear actuator for power SSQA? #71
I agree with what you are saying. I was just thinking outloud. A self centering switch would probably be the best solution. With a click switch I'd be apt to forget it's running while waiting for it to complete cycle and leave the power on. I was just wondering if they are thermal protected at all??
Ya, you can easily run them at a partial stroke. The problem is trying to gauge when the actuator is at the right amount of extension from say back in the seat. Some of the nicer actuators have an adjustable limit sensor on them. That would be ideal for running the actuator part way automatically.
Personally I'm looking for a more automatic solution, so the momentary double throw double pole switch would be annoying. I much prefer the fire & forget double pole double throw toggle switch I have.
As far as protection, many of them seem to have an overload clutch (this one, which is going on the other coop door does Amazon.com: 12-Volt Linear Actuator - Heavy Duty 225 lbs, 12" Stroke Black Finish: Automotive). Most seem to have thermal overload protection. Given the cheap Chinese nature of most of them & more so the descriptions I'm not sure if mine does though.
/ Linear actuator for power SSQA? #73
I think long term some sort of protection will become paramount.
So, when you flip the switch and then go about your business how do you know if the actuator stopped moving because it reached it's limiter switch or because it hit an obstacle it can't overcome??
If we can reach a solution for this problem I'm all about electric. If we can't, then hydraulic is preferred.
This is why they put compression springs on the locking mechanisms. So if you throw the handle into the latched position and for whatever reason the pin cannot fully latch, pressure is constantly applied by the spring until the action can be completed. No harm.
/ Linear actuator for power SSQA? #74
As far as protection, many of them seem to have an overload clutch ....
Agreed that the flip and forget would be ideal IF the actuator is designed to deal with the constant power somehow other than just slipping the clutch at the end of the stroke
/ Linear actuator for power SSQA? #75
Yeah, an overload clutch is not the answer. There has to be thermal protection. And even that is not technically correct. The actuator should not be forced to thermally shut off each time there is a problem latching/unlatching. If it is forced to do that, it's lifespan is going to be very short.
All of the linear actuators I've seen have limit switches. They automatically shut themselves off at the end of the stroke. So no problems leaving the switch "on". Some have adjustable limit switches, but those tend to be a lot more pricey. My current $60 actuator works like that with the fixed limit switches. Flip the switch one way & it extends until it hits the limit switch, then stops. Nothing happens (0 amps of current draw) until you flip the switch the other way.
/ Linear actuator for power SSQA? #77
That sounds good. Thanks for clarifying for those of us that have never dealt with them before.
Apparently I left the 400lbs actuator in my amazon cart when I checked out & it arrived on Friday. I built the new brackets & tested everything out. Brackets are hanging while the paint dries. Only thing left is to let the paint dry, put it back together & get a bungee cord for a little better cable management.
The new brackets are just 2 chunks of bar stock each with 2 holes in them. 1 big hole with a bushing (thanks JMC) & one smaller hole to put a pin through to connect to the actuator. I left overhang on the back of the bar so the bar hit when the motor side was about to go over center. My first try extending the first bracket connected to the actuator & another bar on the other end ended poorly. The 2nd bar/bracket was a hair to long & as soon as both brackets hit the loader arms, unsurprisingly, the 15@ actuator popped the 10@ fuse. Replaced the fuse & trimmed the 2nd bracket so that there was at least 1/4" of slop total between the loader arms & the end of the brackets when at full extension. Works great now. I'll probably blow a fuse if I try to run the actuator with my ROPS lights on (same circuit), but it will provide good positive protection before breaking things.
The cheaper actuator works fine (as long as you get the 6", not a 4" like I did) if you don't mind it taking a little longer & my functional testing indicated that was not a problem. If anybody wants to pay shipping I'll send you my original brackets & the spare bushings I no longer need. You'll just need some longer bolts for the SSQA lever arms & a pair of captive pins or bolts to attach things to your actuator. Paint would be a good idea too.
Will post photos & video in a minute.
Done fighting with this site & attachments on my mobile devices for now. Will try later from my PC
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2012 International (A59230)
2012 International...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
