pat32rf
I laid an 8' 2x4 across the front of "John" and with the help of a coupla eyeballs figured that a 7 1/2' blade looked about right...
I will vote chains as a must. In my experience, bobcats/skidsteers do not push snow well at all. The ones I have seen that were pushing snow had chains on all 4 tires. I think part of the problem is they have no suspension, so that means in many situations you only have two wheels giving traction. And that can change from one tire to another on uneven ground.
We have one with the rubber tracks at work, and it won't do anything in the snow, and that's on pavement.
I have a Kubota BX2200D with a 58" wide blade that angles to about 28 deg. that I built about 6 years ago. See the attached pics. You may notice the blade is angled forward. Works great. The valve is from an Old Monarch belt drive snow plow pump set up. I picked up several of the valves at an auction for practically nothing. I don't think anyone knew what they were??
View attachment 418545View attachment 418546View attachment 418547View attachment 418548View attachment 418549View attachment 418550View attachment 418551
