3PH Pins
/ 3PH Pins #21
I see you got it to work to your liking :D
I would have adjusted the stabilizers, its why they are adjustable. side-to-side sway wouldn't cause any problems so long as the implement or lift arms do not make contact with the rear tires. You can test this sway by raising the implement and pushing on it one way and another.
enjoy your plow! I just picked up a IH 314 rollover (3 16" super chief bottoms) myself to pull with our 706 for terrace upkeep. I'm having fun shopping for wear parts :)
/ 3PH Pins
Getting something to work and have it to your liking are two different things. I would like for the plow to have a bolt on pin. Then I could change out the Cat. 1 pin to a Cat. 2 pin.
If its why stabilizers are adjustable, why do the manufacturers put holes in their implements for lock pins?
What is your 706? Where are you located that your terracing?
hugs, Brandi
/ 3PH Pins #23
hugs, Brandi
sorry, didn't mean to come off like a jerk about the stabilizers... It is common to adjust the stabilizers to accommodate different pin spacing, since implement pin spacing varies so much even within the same category.
Though looking back at your pictures... is the spacing between the lift arms the problem or is it that the lift pin on the plow is to short and your lift arm ball socket butts up against the larger diameter bar (bottoms out so to speak) ?
it is a IH Farmall 706 w/ d282 70hp. I'm in williamson county in the blackland :)
/ 3PH Pins
Texan4Life,
No problem. If you would have read the thread, you would have seen that it a problem of pin length.
hugs, Brandi
1995 Kawasaki Bayou 300 4x2 ATV (A60352)
1995 Kawasaki...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2005 John Deere 7320 (A60462)
2005 John Deere...
LandHonor LHR-AGC4400 4400lb Adjustable All-Steel Gantry Crane (A60352)
LandHonor...
