How do you carry your chainsaw ?
/ How do you carry your chainsaw ? #41
This is what I use to carry my small saw. haven't worried about bending the bar. But I've not tried carrying the big saw this way.
/ How do you carry your chainsaw ? #42
I like the scabbard ideas shown here and will make something like that next. I've found it necessary to carry more than one saw, with the scabbard two of them could be made in the same area.
My first effort was a box for the saw, but it quickly filled with leaves and twigs as much time is spent in the forest brush hogging, dozing brush and fallen trees, logging, etc.
Then I came up with the hangar idea. The saw is protected by the brush guard and has never fallen off, but is less than ideal because the saw teeters back and forth on the hangar. Notice the crow bar stored. I also have places for bar oil, saw gas, chain file and combination wrench.
/ How do you carry your chainsaw ? #43
I purchased the Kolpin chainsaw press and it mounted perfectly to my ROPS using a 2 inch square U-bolt. I even found some nice GREEN plastic covers for the exposed threads on the mounting bolts!
/ How do you carry your chainsaw ? #46
My Setup
/ How do you carry your chainsaw ? #47
My setup so far have more ideas I want to do.
/ How do you carry your chainsaw ? #48
Based on a thread somewhere around here I bought a Kolpin and used two u bolts to hold in on my rops. It worked out so good the next day I ordered a 2nd one so now I can easily carry 2 chainsaws. It's flawless, as I'm sure some of the others are. Glad you all posted this stuff for me :)
/ How do you carry your chainsaw ? #50
here's mine -- built a basket for between the rops and added a toolbar across the back
/ How do you carry your chainsaw ? #52
I would suggest NOT just putting it in your bucket. It is theoretically possible that the saw could bounce out and get run over by the tractor. Theoretically....JayC
I do carry mine in the bucket, still. Although nowadays I put a big orange cone in too so that I can see it sticking up out of the bucket and remember I have stuff in the bucket.
I had a brain fart one time and dropped the bucket, picked up a load of dirt and rocks and transported it to another location and only realized I forgot the chainsaw was still in the bucket after I dumped it. Had to disassemble the entire saw to get all the impacted dirt and pebbles out of it. The wonder is I didn't destroy it.
/ How do you carry your chainsaw ? #53
In the bucket of the tractor along with a jug of gas and a jug of chain oil.
/ How do you carry your chainsaw ? #54
I take it that you never put the ROPS up?
That's correct. I have flat ground and LOTS of trees...that ROPS will catch a limb and bring the front end 3 feet off the ground in a HURRY....safer to leave it down.
/ How do you carry your chainsaw ? #58
I've done the same thing basically.. had the saw on a load of wood in the bucket, then forgot about the saw and 'dumped' it with the wood. Lucky, like you, no damage.
I used to carry it secured by the bar, but bent the bar the first or second time I ran over a stump. Got to put on a chassis mount.
/ How do you carry your chainsaw ? #59
I can carry up to three chainsaws each in their individual holders.
I carry my Stihl MS 362 CM in a holder mounted on the right side FEL frame. I carry my MS 440 Magnum and my Husky 350 both in their holders on my carry-all that's attached to my BB.
Here's a pic showing all three holders, although the Husky is not mounted. After getting my MS 362 CM, I don't have much use for the Husky.....
/ How do you carry your chainsaw ? #60
Let's see, 2 chainsaws, fuel, an AR, if you only had a coffee maker, you'd be all set.
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
New Holland 256 Hay Rake (A65579)
New Holland 256...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
JOHN DEERE 6155R TRACTOR (A64277)
JOHN DEERE 6155R...
2021 KUBOTA RTV-XG850 SIDEKICK RTV (A64277)
2021 KUBOTA...
