4 in 1 bucket or Grapple??
/ 4 in 1 bucket or Grapple?? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So I bought a new to me tractor with a WR Long UJ2-62WR 4 in 1 bucket, but with the mess I have in some of my woods I'm thinking a grapple might be a better thing. I've never really used either one, my new 4 in 1 a little but only very little. So what do you guys think? 4 in 1 or grapple?? Can I ask here if someone would be interested in making me a trade, or is that a no no?
/ 4 in 1 bucket or Grapple?? #2
I have both a 4-n-1 and a grapple. They are sufficiently different that I do not think of them as substitutes for each other.
I keep the 4-n-1 on the machine most of the time, but if I have brush, logs, trees, large rocks to move, the grapple goes on and the job is much easier.
/ 4 in 1 bucket or Grapple?? #3
If you are clearing debris in your woods, a grapple is the way to go. No doubt.
/ 4 in 1 bucket or Grapple?? #4
Grapple: http://www.tractorbynet.com/forums/attachments/267492-wicked-root-debris-grapple.html
/ 4 in 1 bucket or Grapple?? #5
I also have both. I mostly do land clearing/bush hogging but also do some backhoe work. Rule of thumb is that for anything that requires gathering/clamping/moving brush, trees, stumps etc then the grapple is far superior. I mount the 4n1 essentially only if I am digging with the BH and need to refill and smooth out the dug areas afterwards. I have the grapple mounted about 80%. 4n1 about 10% and standard bucket or special 3pt adapter about 5% each. I could live without a 4n1 if I had a grapple and standard bucket. No way could I live without a grapple.
The 4n1 is extremely inefficient at collecting and securing brush/logs simply because it is a top hinged pincer. Whatever object goes in first is held in place by essentially jamming the jaws open. If you load a 3" branch first then nothing 3" or smaller will be able to be clamped after that. The 4n1 works fine to grab any individual object but it is not nearly as flexible as a grapple that scoops up any type of load and then simply clamps to provide a bit of stability.
Also, 4n1 buckets are way more expensive than grapples.
My advice: get a grapple. If you find there is a specific task you need a 4n1 for add it later. IMO the only people who really get benefit from a 4n1 are contractors who need to have the flexibility of the 4n1 as a single implement on a jobsite and are using it as an all purpose Swiss army knife with attendant inefficiencies.
I already have the 4 in 1 bucket, it came with the tractor I bought. I was trying to figure out how much I really want it. I've decided a grapple would be more useful to me cleaning up my new homestead. I cannot afford both right now... just bought a place, a tractor, ordered the Caroni yada yada yada.. need to figure the best way to go about making the switch.
How big is your tractor, by the number I'm guessing a 40 HP? How big is your grapple and what kind is it?
/ 4 in 1 bucket or Grapple?? #7
I was in the same boat and able to trade my almost new 72" JD 4 in 1 for a new 72" NAI grapple for my skid steer. It did cost me $400 to trade but it was worth it to me.
/ 4 in 1 bucket or Grapple?? #8
I already have the 4 in 1 bucket, it came with the tractor I bought. I was trying to figure out how much I really want it. I've decided a grapple would be more useful to me cleaning up my new homestead. I cannot afford both right now... just bought a place, a tractor, ordered the Caroni yada yada yada.. need to figure the best way to go about making the switch. How big is your tractor, by the number I'm guessing a 40 HP? How big is your grapple and what kind is it?
My tractor is 40hp and has lift capacity of about 2700lbs. My grapple is a light duty 48" open bottom style. Made by Millonzi who is out of business. If I had to replace it (It is fine despite aggressive use for about eight years) I'd probably get one of the light/medium weight 54" or 60"(max) single lid grapples from Everything Attachments. I'd actually prefer a 48 but they don't make that for a 40hp. My current grapple is essentially a generic style and there are many manufacturers who make similar grapples. I am impressed that virtually all the generic grapple manufacturers are just welding shops and put very little thought into their product. Everything Attachments has put a lot of effort into designing a true light duty 50" grapple that is limited to 35 hp. The 54/60 is a hybrid of the bottom from a heavier grapple plus the lid from the light duty. Best compromise available IMO right now for 40-60 hp CUTs.
If I was in your shoes I'd sell that 4n1 in a minute to get a true grapple.
I believe that will be my plan, what do you think its worth? great shape hardly had the paint scraped.
2020 MACK P164T (A60736)
2020 MACK P164T...
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
John Deere 1518 (A60462)
John Deere 1518...
DRAGON TRAILER MOUNTED TRANSFER PUMP (A60736)
DRAGON TRAILER...
2017 Versatile 260 (A60462)
2017 Versatile 260...
