Quick Hitches 3-point quick hitch
/ 3-point quick hitch #21
/ 3-point quick hitch #22
I like the 3-point quick hitches with 7/8" lower hooks in conjunction with a hydraulink top link. A Speeco Cat I quick hitch #HF141160 for $200 is perfect for tractors under 40hp. The hydraulink top link ($200) allows you to extend and retract the top link from the seat of most small tractors. Quick hitches work best if you can lead with the top hook and allow it to fold back as you line up the lower hooks. The hydraulink makes this quick and easy. You won't be disappointed.
/ 3-point quick hitch #23
Most major implement manufacturers make their current products quick hitch ready. For instance, all new Woods implements will fit a standard quick hitch.
/ 3-point quick hitch #24
Are you guys saying that there are QHs that don't require bushings on the lift pins? In other words, the slot on the QH is made to accept a 7/8" pin? I wish mine were that way. I have a small fortune in the bushings. They're either $35 at TSC or $13 + $8 S&H at Northern tool. I just bought 3 sets (only needed one more set) and they're on my porch right now. Bought 3 to save on shipping. The "i'll use them eventually" philosophy.
/ 3-point quick hitch #26
This is the Speeco E-hitch versus the Speeco "Cat 1"?
The one our Fleet Farm sells I swore took the bushings (which they sell), but now I'm not sure as it's only $200.
/ 3-point quick hitch #27
Partspring... You said the Speeco e hitch is "perfect for tractors under 40 HP." Speeco rates it to 50 HP.
I just bought one for my DS4510... Are you suggesting that Speeco is wrong in their ratings? Hope I don't have reason to regret my choice.
/ 3-point quick hitch #28
Mine takes bushings, but I wish I knew about ones that didn't. I don't understand why they are designed to take bushings.. Seems like a racket!!
/ 3-point quick hitch #29
I did a bit more poking around the net last night & found that there is very little difference between the regular Speeco CAT 1 hitch & their "economy" model.
The size is the same. The weight is the same. For some reason the top link extension accessory is different. The only big difference that I could see is the "E" version doesn't need bushings to adapt to cat 1 implements.
According to Ted at EA, (check out the video) the economy version is a bit fussier to line up when connecting an attachment. Otherwise, there is no difference.
/ 3-point quick hitch #30
Maybe a racket, but the standard for quick hitch dimensions and pin sizes is an international standard maintained by the American Society of Agriculture Engineers. I think the logic was to consolidate all implement pin sizes to Category III but I'm not sure why that makes sense since the horizontal pin spacing still varies by Category.
/ 3-point quick hitch #31
But there are a few that are 7/8 size and do not take bushings. But the majority do. Are they thinking about a "wear item" that is easily replaced?
/ 3-point quick hitch #32
I have an older Land Pride Cat 1 hitch that is sized for Cat 2 pins.
Bruce
/ 3-point quick hitch #33
The only QH that doesn't require bushings I believe is the Horrible Fright one.
/ 3-point quick hitch #34
ASAE Category 1 Standard S278.6 for quick-attach hitches
More than you ever wanted to know about QH's:
www.virtual.unal.edu.co/cursos/sede...df/asae_s278.6_enganche_rapido_modificado.pdf
Patent US5029650 - Adjustable quick attaching hitch coupler - Google Patents
/ 3-point quick hitch #36
I have a speeco cat 1 quick hitch and love it for stuff its fits, and plant to modify anything that doesn't fit to it! I thought the JD imatch had difference spacing from the lower link to the upper link...which makes it unique to JD, thus encouraging people to buy JD implements..? Could be wrong.
/ 3-point quick hitch #37
The JD follows the exact ASAE standards I linked to above, as do most other QH's. Everybody likes to think/saw the JD is proprietary, that only JD implements work with it, or that they cost more than all the others because they are green...but none of that is true.
/ 3-point quick hitch #38
Thanks James. Except for the price and color though, do you see a difference?
/ 3-point quick hitch #39
My HF Cat 1 hitch is set up for Cat 3 bushings.
Bruce
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
