Using rear remotes for a grapple
/ Using rear remotes for a grapple #21
My B2710 has a 3-spool rear hydraulics valve. I would like to use the middle valve to run a grapple-like device. Hows the ergonomics of using a right hand to operate a grapple by rear hydraulics?
/ Using rear remotes for a grapple #22
My B2710 has a 3-spool rear hydraulics valve. I would like to use the middle valve to run a grapple-like device. Hows the ergonomics of using a rear right hand to operate a grapple?
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=408705"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=408704"/>
Its not ideal compared to a switch on the fel control but there are lots of folks that do it. I've got a 4 spool with one just waiting for me to plumb it to the front.
/ Using rear remotes for a grapple #23
Sodo, in my opinion where your hand needs to be on the FEL control and then reaching back to operate the spool for lid control, is gonna suck. It will really slow down your operation. That is just the best way I know how to put it. I am a proponent of using rear remotes to save money on grapple installs, and that is what I use, but I can keep my palm on the joystick and operate the lid with my fingers of my right hand. I am not saying you can't do it, because you can, but it will not be a joyous operation. In my opinion.in use.jpg
/ Using rear remotes for a grapple #24
Thanks james, I'm inclined to do it just to get going, and then add forward controls later if it becomes non-joyous. Most of what I need is to be able to drive into a pile of brush clamp down on it and go to the burn pile without losing half of my load.
/ Using rear remotes for a grapple #25
Well, you will certainly be able to do that, just not as fast as you may like. But if you are in no gigantic hurry, then of course it will work.
/ Using rear remotes for a grapple #26
If I had a "lid" to hold down huge fluffy piles of brush onto my brush fork (travelling to the burnpile) I'm gonna have to start growing more brush just to keep up with this unit. :D
/ Using rear remotes for a grapple #27
Thanks so much for the link on how to do it. The seat pan removal was the biggest PIA. The detents ball removal was very easy and I have them in a zip lock bag should I ever need them, although I highly doubt it. Used the grapple extensively yesterday and boy what a difference in production when you're not worried about getting stuck in the detent position.
/ Using rear remotes for a grapple #28
Yep, that's the way to go.. pay it forward, hang around and help someone else when you can.:thumbsup:
/ Using rear remotes for a grapple #29
K0ua,
Good comments and recommendations. I'm sure you have been using your third function for a good while now!:thumbsup:
I agree about the detent valve beeing too easy to trip on. But they have their purpose, as they are usefull runing a motor, like found on spreaders. Only one hand action is the best for rapid action. Also, I beleive their role not to be as appropriate on compact(under 50) and smaller tractors. Also, as hydraulic flow is insufficient on those, why so many owners hooking up log splitters?:confused:
/ Using rear remotes for a grapple #30
I would absolutely get a diverter valve so that you can get a 3rd function on the loader curl with a push button on the joystick. If you place it on the loader arm after the original 4 QDs, it's very cost efficient.
/Marcus
/ Using rear remotes for a grapple #31
/Marcus
A solenoid diverter valve switches between two circuits, and the curl lever controls the final output, and can be feathered.
A 3rd function valve uses a solenoid to operate a cyl at full flow. It is usually in the series flow path after the FEL valve.
/ Using rear remotes for a grapple #32
Well, I don't agree on the nomenclature. 3rd and 4th function are just names of aux hydraulic outlets on the FEL. How they are implemented is another question. On a modern loader, diverter valves is the standard solution to get 3rd & 4th function as well as hydraulic implement locking.
If you order a new Alo-Quicke loader and specify 3rd and 4th function you will get a double diverter valve on the lower cross-bar. You will not get additional circuits from the tractor hydraulics and 4 extra hoses to connect between tractor and loader.
I also think it' s a much better solution for most tasks.
/Marcus
/ Using rear remotes for a grapple #33
If you have two remotes, you can do T-N-T .
JJ, A newbie question. What is T-N-T and what can you use it for. Trying to learn the acronyms. Thanks
/ Using rear remotes for a grapple #34
Well it is not an explosive:). TNT is shorthand for Top-N-Tilt. Meaning the top link jackscrew of your 3pt hitch is replaced with a hydraulic cylinder and the Side link or sometimes called the Tilt jackscrew of your 3pt hitch is replaced with a hydraulic cylinder. What good is this you say? Well it can be used for many things, one example would be when using a rear blade either box or grader blade, you can adjust the top link from the seat on the fly as you are using it instead of stopping the tractor, getting off, adjusting the top link manually by screwing in or out the jackscrew, getting back on and checking your angle of attack on the blade, and deciding it is not right and repeating this over and over until you are satisfied with the angle.
Likewise the Tilt angle of a blade can be adjusted as for example when making a ditch by a road you can adjust the the angle as needed without getting off of the tractor. All of this is to just have the ability to make these adjustments quickly from the seat. I can tell you that without TNT, (which I don't have). Grading and spreading dirt in a precise manner without it can result in a lot of trips on and off the tractor.
Also TNT can be a great aid getting hooked up when using a quick hitch to match up with implements that may have settled into the ground unevenly.
It can also be useful to carry implements higher when transporting them, and for a mower to be able to raise it higher to accommodate backing up a very steep bank or hill. There are probably a lot of other uses for it, but I don't have it so I wouldn't know.:(
/ Using rear remotes for a grapple #35
So James K0UA - several years have passed. You still using this grapple method and how do you rate it. I'm giving some thought to it. Kioti now offers 3rd function and dealer said about $1,000 installed..
/ Using rear remotes for a grapple #36
Yes, still using it and this method, and on a Kioti with the conveniently located rear remote lever, and extended the 4 inches, I rate it A+. I would not put the electric over hydraulic on if someone gave me one. I would sell the 3rd function for money. I especially like this method because I can "feather" the amount of squeeze easily and probably because I have become so good at operating it. Now if the lever was beside you or some other location not handy, it would be a PITA. I think the Kioti is unique in placing the lever so strategically with only needing to extend it to become Really effective and fall to hand naturally.
/ Using rear remotes for a grapple #37
Same with the use of rear remotes for my front plow. Works great. No issues at all. And way way cheaper
/ Using rear remotes for a grapple #38
Great to hear, with my NX they are beside me. I have 3 rear remotes and the front one is detent for my backhoe. Thought about just switching the front and rear levers then see about making a handle for the front. But if I cant come up with a factory look I won't do that. May look at it when there is heat in the air..think spring.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 LandHonor HPF-11-3000G 48in Hydraulic Adjustable Forks and Frame Skid Steer Attachment (A60352)
2025 LandHonor...
Expandable Conveyor Belt on Wheels (A62177)
Expandable...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2021 International HV507 4x4 Crew Cab Dump Truck (A61568)
2021 International...
