Ventrac 4500 vs Steiner 440
/ Ventrac 4500 vs Steiner 440 #1
Bearsden
Member
Canaan Valley, WV
Kubota BX1500, Ventrac 4500Y
Hi. First post here.
I'm a member of the Maintenance Committee in a gated community in West Virginia. We cover 2,700 acres with about 26 miles of roads, 500 acres of common conservancy areas and two good size lakes with dams.
We have an old Husqvarna riding mower which is sorely in need of replacement. In addition to simple grass mowing we would like a product that would be able to take on some chores that we have been contracting out, such as mowing the dams and parts of the conservancy areas. We also want to use it for mowing hiking trails and blowing ditches in the Fall.
Our Maintenance Staff has done the research and have come up with what they want which is the Ventrac, as follows:
  • 4500K Tractor
  • 4500K Accessories Kit
  • Dual Wheel Kit with standard all terrain tires
  • Slope Indicator
  • Side Discharge Mower
  • Tough Cut Mower
  • Tough Cut Swivel Wheel Kit
  • Turbine Blower
  • Slope Indicator
Another member has popped out of the woodwork and wants us to also look at Steiner due to his supposedly bad experience with Ventrac while director of a nursing home complex.
We are being told that we would better off with an air cooled engine vs water cooled due to the frequency of the radiator being easily clogged from a lot of mowing. We are also being told that the available diesel is quite a bit underpowered.
Comparing the two, they are quite similar, but with subtle differences. One thing that really jumped out was the advertising or lack thereof when it came to slope mowing. Ventrac seems to have a ton of both text and videos on the subject with no real mention made by or about Steiner. Ventrac has a Slope Indicator as an option, but couldn't find such for Steiner. Ventrac seems to be about 7" wider with the dual wheels. Steiner is offering a bit more HP on their air cooled with the Kohler engines.
Any thoughts, experiences, comments or suggestions would be appreciated. Thank you.
/ Ventrac 4500 vs Steiner 440 #2
:welcome:
To the forum from Alabama. I don't have any experience with these but I am sure the people who do will help you out.
/ Ventrac 4500 vs Steiner 440 #3
I have the "under powered" Kubota Diesel and I have yet to find it lacking. I use the Snow Blower and shoot snow 30' easy. I cut 5 acres of grass weekly with the 60" side discharge mower. I have no complaints on this machine at all. I was lucky enough to test drive them both as my dealer sold both. Steiner was having control problems at that time. If I was to go gas I would go with the Kawasaki engine.
/ Ventrac 4500 vs Steiner 440 #4
Welcome, I too have the kubota diesel. I cut around three acres weekly with a 72" side discharge deck,plow four drivewaysof snow , plow my garden, till my garden,move materials around my property with the slip scoop, and building a set of forks to move other things around.I tried the Steiner as my dealer sells both and like some of the features on the ventrac better. the belt tensioner is awesome as with the weight transfer lever. the Ventrac has SDLA controls that make it really fast as to moving the machine forward and backward and being able to raise the attachments up and down with out moving your hand from one lever to the other .I also have the 3pt hitch on mine that I use a lot for different things. The oil cooler is reversible by just flipping a switch and blows heat into my cab. This is all a personal preference of which machine you like.I have had mine a year and a half and have had Zero problems.
/ Ventrac 4500 vs Steiner 440 #5
The Steiner 440 seems to be slightly longer than Ventrac ...not sure about the duals being available on it. I can tell you a steiner 420/430 with duals is just as capable as a ventrac on side hills ,I can't speak for the 440...I tend to agree about the liquid cooled engines especially when using mowing decks, the radiators tend to quickly draw in the grass especially dry grass on an afternoon cut...the other side is the air cooled engines will need there screens cleaned too and blown out often,either way neglected maintenance and daily cleanings will result in overheating and engine damage.This is more of an operator issue,and training issue. I think the kubota diesel is plenty powerful as long as your not trying to run the 84 inch deck and are willing to slow down a tad as needed.
/ Ventrac 4500 vs Steiner 440 #6
I have had 2 4231 Gas Liquid Cooled Ventrac Tractors with zero real problems with over 1,500 hours - I would not worry about radiator clogging - there is a good screen that takes less than a minute to remove and shake out. The Ventrac is heavy duty commercial quality and I would go with the Kawasaki Gas if you are doing slopes (it is rated for continuous duty on 30 degree slopes) My neighbor has the 4500 P (Kawasaki) and loves it. I have heard that the older Steiners were built better and stronger than the new ones. I am partial, but would recommend the Ventrac. Attachments are great and I have never had problems with product support. Look in the other Ventrac Forum posts - I do not believe you will find many negative posts about Ventrac. :thumbsup:
/ Ventrac 4500 vs Steiner 440 #7
I just recently acquired a Ventrac 4500Y. You can read why here. My main reasons for choosing the diesel were the greater weight, the greater dimensional stability of liquid-cooled engines, the longevity of diesel engines, and the lower fuel consumption. The heaviest load that I have placed on the tractor so far is using the rotary broom while moving uphill on a paved driveway with a 14° slope. The tractor fulfilled the task without hesitation or complaint. I am very pleased with my purchase.
I chose the Ventrac over the Steiner for the weight transfer and the SDLA control joysticks.
JJM
JJM
/ Ventrac 4500 vs Steiner 440 #8
I have the 440 with the deisel. I would say that the power is adequate for it with the 60" finish mower and the Ventrac tough cut mower I use on mine. I also have very hilly terrain. I have the wheel spacers on mine but duals are also available for the Steiner as well. As Raw Dodge stated keep the radiators clean and you will have no problems with them. I bought mine the first year out for the new model and have had several problems. Steiner and my dealer have been excellent about fixing the problems and most of them were repaired with upgrades. I think both the Ventrac and Steiner models have been out long enough that they should have most of the new model bugs worked out ( I hope). JackIL recommended the weight transfer to me and I in turn recommend it also. It makes a big difference with the finish mower on the hills I mean night and day difference. It is an option on the Steiner that can easily be added by yourself later on. I love mine and would buy it again.
Thanks all for your comments. We'll take them into consideration during our decision making process.
Was hoping to hear more on why Steiner doesn't brag about slope mowing capability.
Another question that just came up was how do either do with the Tough Cut mower in wet conditions? The trails we have to mow do have wet spots.
/ Ventrac 4500 vs Steiner 440 #10
It will cut wet material fine. I do not have wet spots that I mow with mine. I would think the lack of ground clearance can be an issue with them if the areas are fairly mushy or swampy. Don't know why Steiner does not brag about slope capabilities. They do not have a very informative website either. I did scan a couple pages out of my owners manual about slopes for you.
/ Ventrac 4500 vs Steiner 440 #11
I don't know why Steiner does not brag about slopes, but what I have heard is that Steiner was designed by the Father of the Steiner Brothers that started and are still involved in the Ventrac line. I heard that Ventrac was started because the Brothers were not happy with what the new owners of the Steiner brand were doing with the tractor.
ON the subject of how Ventrac does in wet conditions - The tires are high flotation and especially with the Dual Wheels attached they do better than many tractors unless it is someplace no tractor should go anyway. We have red clay soil here and it gets slippery - I have taken my Ventrac places that I would never have gone with my 318 Deere (I had wide Ag type tires on the 318). The Tough Cut seems to very well on my neighbor's 4500 (even in wet conditions) !
/ Ventrac 4500 vs Steiner 440 #12
For whatever reason Steiner is seriously lacking in the marketing department. I see very little about them in fact most people still haven't heard of them even though they've been around for over 30 years. I think the Steiner Brothers under the Ventrac name have done a great job of marketing the Ventrac product. I apologize if I'm wrong here but I think it's Denver Steiner who has been doing most of the YouTube videos and work there. Whoever it is it's a great idea and those videos are very important to prospective buyers. Many people have taken part in excellent videos on YouTube including Jack il. I cannot overemphasize how important they are in today's market and I think Steiner has just totally given the internet marketing to Ventrac...by not participating on a level that shows they are a true player.
Thanks for the feedback. Will report back on what we decide.
Whoops, another question. For those of you who have purchased new Ventracs, what is the typical time between ordering and delivery, assuming the dealer doesn't have the tractor in stock and it has to come from the factory? Or do dealers also attempt to find one in stock at another dealer as do some auto brands? I see that based upon Mr. McVeigh's thread it was only 21 days between order and delivery. Is that typical?
/ Ventrac 4500 vs Steiner 440 #15
I bought mine from stock as he is the biggest dealer in these parts. He stocks at least 10 Ventracs and 5 steiners plus 2 buildings of attachments. Mast Lepley is my dealer
/ Ventrac 4500 vs Steiner 440 #16
It is my understanding that Ventrac builds tractors and attachments according to a certain schedule. Seasonal items are produced according to anticipated demand. E.g., there is not much demand for snow blowers in the Summer, and there is not much demand for mower decks in the Winter. Production runs of such seasonal items will be scheduled so that the items can be delivered to dealers on a Seasonal basis... e.g., mower decks in early Spring and onward, snow blowers in early Fall and onward.
When I placed the order for my 4500Y, it was the last one, or one of the last ones, coming off the previously scheduled production run, and a new run of the Y variant would not begin for some weeks. There were then-currently no rotary brooms available directly from the factory, and a new production run of brooms was not scheduled for some time. My dealer spoke with Ventrac's District Manager. The District Manager located a broom at a dealer in Virginia or North Carolina. The District Manager personally drove to the dealership that had the broom and delivered it to my dealer, who in turn delivered it to me on December 27, along with the tractor itself and the other attachments that I had ordered.
As Murph notes, large dealers often keep substantial inventory in stock. Smaller dealers cannot afford to do that. My dealer is one of the smaller ones.
At the time that I placed my order, a larger dealer about 75 minutes West of here had a 4500Y sitting on the showroom floor, waiting for a buyer. Both that dealer, and the dealer from whom I purchased my 4500Y, had snowblowers in stock.
With best regards,
John
Thanks again. And now another question from out Maintenance Committee. What's your experience from a maintenance standpoint? Can any provide a rough idea of what to expect for yearly maintenance cost. I know it will depend on usage. Ours will not be used in the winter. Our usage will probably be closer, but less than what one might see for a gold course.
/ Ventrac 4500 vs Steiner 440 #18
As a new owner, I am not well positioned to answer your question as a matter of past personal experience. What I can say is that, from reviewing the Owner's manuals, the routine maintenance (motor oil and oil filter changes, application of grease to various zerks, etc.) is of a nature that a person with basic mechanical skills should be perfectly capable of performing.
So, the question that you pose leads to another question: will your organization hire the dealer (or someone else) to perform all required maintenance, or will your organization do some, most, or all of the routine maintenance in-house? If your organization will hire the dealer or someone else, you might ask that person what the anticipated charges will be.
JJM
Routine maintenance will be performed in house. I'm looking more at the non routine things that might go wrong and what we might expect to spend over a ten year life.
/ Ventrac 4500 vs Steiner 440 #20
How many hours are in a ten year life? What is a planned non-routine problem?
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
New Holland 3930 (A60462)
New Holland 3930...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2014 Ford Expedition SUV (A64557)
2014 Ford...
