Ventrac 4500 vs Steiner 440
   / Ventrac 4500 vs Steiner 440 #41
As it is now. I have to watch for stepping in deep mud or going *** over tea kettle on some ice. Cutting grass seems years away! Any maiden voyage of this (new to me) mower now, might well involve some altercation with an ice berg! This is the slowest thaw I remember in a long time. Not a bad thing I guess. Usually we have -20c one week and + 30c the next!
I will be tickled pink if I can finally cut grass with my Steiner without thinking about which way the grass flies. One building in particular is built into a hillside that ends at a tree line and I have had no choice with the side discharge mower, other then to blast the wall of the building.
   / Ventrac 4500 vs Steiner 440 #42
I think we all have that building!
prs
   / Ventrac 4500 vs Steiner 440 #43
I learned early on to cut with the discharge away from the buildings. i never used a rear discharge with a full roller but as the grass blows out the rear it hits the front tires and causes it to windrow. With a full with roller it may stop that but if it's wet or a little long it may get interesting…….
   / Ventrac 4500 vs Steiner 440 #44
I have both the Side and Rear discharge 60" Ventrac mowers. I have lots of steep slopes as well as a 22 degree lake dam that I mow. I prefer the rear discharge as it is a bit lighter, is easier to trim with, and doesn't clog nearly as bad as the side discharge when mowing damp or higher grass. It is also quicker to mow with as you can make a pass in any direction without worrying about grass clippings that have been discharged to the right side. It is also a cleaner mower to use as the clippings fall straight down and do not blow on you as can happen with the side discharge, on a breezy day, mowing dry grass. It does windrow, however I mow my fescue at 4" so the effect is minimal. I mow with the 4200 water cooled diesel so on very dry days you do have to watch the water temp and stop occasionally to clean the radiator screen. About the same effect you have when using the Tuff- Cut on pasture. The rear discharge also does a better job of mulching leaves in the fall using the standard mowing blade. I've never tried a mulching blade on it.
We have about 2 acres of level low area where my wife likes to use our 4100 25HP gas with the side discharge mower. It does a nice job and she generally mows with the chute discharge down to minimize windblown debris.
I have the dual tire setup for the 4200, however generally don't install them unless mowing very wet pasture areas.
I've owned the 4100 6 years and the 4200 4 years. Both have just needed routine maintenance and occasional belt replacement. The PTO clutch failed on the 4200 under warranty and the dealer came to our site and replaced it.
   / Ventrac 4500 vs Steiner 440 #45
I did get a nice surprise with the Steiner 440 hydraulic is head over heals more powerful than the VT. and i do like the two brakes for safety. The rest is still up in air the as of now, but it does hang on a slope good and weight transfer can be adjusted on the move, nice feature…….. jim
   / Ventrac 4500 vs Steiner 440 #46
That (the low hydro pressure) is the only real complaint I have with the Ventrac. I would love it if they would boost that pressure. Now that mine is out of warranty - I would love to have that pump boosted to max pressure.
   / Ventrac 4500 vs Steiner 440 #47
The low pressure is always the complaint...and boosting it doesn't always give the desired results.. The best way to explain it would be to tell you that you would like more pressure at your sprinkler head on your lawn so it will spray further.Lets say there is a pressure regulator on the sprinkler head it is set at 30 psi the water pressure coming in the hoses 60 psi but the hoses 75 feet long and has a few holes in it along the way , in time the leaks get bigger and if that garden hose was buried under the ground and you didn't see the leaks you may be tempted to go to the sprinkler and turn up the pressure setting as you know this will not help if the leaks bleed off enough pressure to keep the pressure at the tip about 30 raising the pressure there will not do anything, unless you replace the leaky hose......just like this leaky hose ... Your ventrac hydraulic system has internal leaks that are normal.. When it is new these leaks are minimal and the low pressure pump supplies the high pressure pump that operates the wheel motors. That's the part that's important to understand, because usually when there is low pressure or slow operation in the low pressure system the steering and lift it is the result of a leak in the high pressure system this leak causes the low pressure pumps full capacity in gallons per minute to be used to supply the high pressure pump with fresh fluid to overcome the leaks this leaves the low pressure system with very little reserve capacity and anything you do to lift or steer may cause the low pressure systems gpm to be inadequate to do both, and the low pressure systems pressure falls below the relief valve pressure set point.. If this is what's happening raising the pressure will not help you , while it is cold you may think it's better, but then once it's hot as soon as the machine fully warms up you will have the same exact problems..Steiner added a second pump to the 440, they added enough flow to compensate for normal wear down the road and to allow for hydraulic capacity to always be available no matter how hot the machine is. My guess is that Ventrac hasn't done this because it is a cost issue and also space is limited under the hood. it's my opinion that the hydraulic pumps that ventrac Steiner use, were originally intended to run 1 hydraulic motor, similar to something like a Steiner 230, adding a second motor to allow four wheel drive causes extra internal pump leakage double that of a two wheel drive. here and is where I believe the problem lies once these machines get some time on them in the motors get some wear, and starts to bypass more oil, because you have two of them you have double the leaks that it was designed for so the little 1.2 gallons per minute pump just isn't quite enough for a dual motor system like a Steiner Ventrac, if the system is in tip top shape there is no problem. I believe the owners at ventrac are pretty smart, this is why they use amsoil, and the extra return line filter on the rear to help minimize internal wear and provide the most service life possible before the pumps and motors need to be resurfaced.
   / Ventrac 4500 vs Steiner 440 #48
Excellent post and a good example as to why low hour drives are a lot stiffer and noisier than high hour drives. As the rear pump wears the front pump doesn't bypass nearly as much. Also a good reason to avoid the duals as much as possible as they just add to the stress of the rear pump when executing tight turns. My 4100 with 1400 hours has much less drive noise than my 4230 with 750 hours.
   / Ventrac 4500 vs Steiner 440 #49
Raw Dodge, do you think the BestLine Powertrain Lubricant additive would slow the wear-out internal leakage process?
prs
   / Ventrac 4500 vs Steiner 440 #50
I dont have enough long term time to know yet, I use it, in both steiners and my ventrac. .I've only been using it a little over a year. I'll tell you that they definitely operate smoother and with less pump whining.i usually redo the rear motor every few seasons,this keeps the systems in good shape and keeps leaks to a minimum. Its not hard work but it's messy and time consuming also requires a very clean work area.
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
