OP
rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,417
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Got the table top for the control valves cut and cleaned up from a piece of 10 ga. hot roll that was a drop ... rounded off the corners, smoothed the edges, and drilled the holes to mount the control valve for the cylinder for the pusher block. Made the table big enough to accommodate a second valve - which I don't have yet - for the log lift.
Still need to get the cylinder up on the beam to figure out the exact mounting location for the table.
The valve in the picture is a Prince logsplitter valve - think it's an LS3040 - it's a double detent - so it will extend or retract the cylinder unattended.
Will probably go with a Prince RD5000 series valve with Power Beyond for the log lift.
