Trailer for DK 40se
/ Trailer for DK 40se #1
Brokermike
Shaftsbury VT
Mahindra 2555, Ford 4610, New Holland T4040
Decided to keep my DK 40 rather than buy a newer higher hp tractor. Tier 4 pricing scared me to death. Anyway. Looking for trailer suggestions for my dk 40se. I have a loader and loaded tires with chain. Is an 18' car trailer heavy enough. It is a 3.5 ton trailer?
I'm trying to buy used and have it serve double duty to haul the occasional building supplies and pallets of pellets for my folks
Thanks
/ Trailer for DK 40se #2
I'd say no to a 3.5T (7000 lb) trailer. Say the trailer weighs 2K. That puts the trailer load capacity of a 7K trailer at 5K.
Your DK40SE weighs 3942 (with cab would be more), loader is another 1284, Loaded tires and chains etc about 1200. That puts your weight at about 6426 lbs. I'd say you need a 5 Ton (10K) trailer and at least 20' if you ever need to haul implements with your tractor.
I recently sold my 20' 7K trailer for the same reason. I bought a new tractor that weighs about what yours does. Too much for a 7K trailer. I could have got away with a 10-12K trailer but went with a 22' 14K PJ tilt bed.
/ Trailer for DK 40se #3
We have a DK45 with FEL. We chose a trailer with 5k axles. It's 18 foot so if we haul the brush hog, it hangs off the back, but nothing crazy. Make sure whatever you get has brakes.
/ Trailer for DK 40se #4
As others have said 7 k is to light 10 k min. 20 to 22 foot should be about right. I'm in near the same situation as u I'm still shopping.
/ Trailer for DK 40se #5
Thanks
I would say go extra and get a 20ft.Nice to have the extra 2ft. if you a implement on the rear.I went with a 20ft.PJ trailer with 7,000 lbs axles.I also burn wood pellets nice to get 4 skids (8,000 lbs)in one load verses two trips.
/ Trailer for DK 40se #6
Like the others said you'll need a 5 ton/10,000# minimum. My tractor showed up with front snow blade andblower mounted and it took up every inch of a 20' trailer, with the blade on top of the front rub bar. I have a guy building me a 26' 7 ton so I can handle trailer and anything else.
/ Trailer for DK 40se #7
Thanks
I was in the same situation although I kept my CK 30 TLB and added a DK45. I was using a 7000lb carhauler but went to an Anderson 20 foot 14k goosneck. The GN gives me extra space when using multiple implements
/ Trailer for DK 40se #8
As others said, 7k is too light.
As to length, measure your longest setup. My smaller tractor+fel+6' bushhog is longer than 20'. An no way would it go on an 18' and have good weight distribution.
/ Trailer for DK 40se #9
Thanks
What is your tow vehicle?
I tow with a 3/4 ton truck, have owned more trailers of all types over the last 30 years than I can remember, but this is the best one, got it in 2006.
18' steel deck plus the 4' pop up dovetail 14K gooseneck from: Welcome to Delta Trailers
Removable flip over ramps with hinged loading support legs.
Led lights and receiver hitch.
Use it this way to haul round bales.
Use it with the pop up up for square bales.
/ Trailer for DK 40se #10
I use my 7k hauler for my DK40SE, but I only take my brush hog along for the ride. I've been looking for a longer, heavier duty trailer so that I can tow my tractor with the loader and hoe, but then I'd have to upgrade my pickup as well...
/ Trailer for DK 40se #11
I have a dk50se hydro with loader and a woods 90x backhoe, haven't loaded the tires yet. I bought a 7 ton 22 foot PJ trailer, is the equipment hauler type with fenders not the higher flat deck, bumper pull hitch 2 5/16" ball. Pull it with a f150 right now, handles it ok if loaded properly
/ Trailer for DK 40se #12
Thanks
I have a 20' and I wish I had purchased a longer trailer so I could carry attachments as well as the tractor.
/ Trailer for DK 40se #13
Looks like you need a bigger truck instead of trailer.
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
Rooster Weathervane (A61574)
Rooster...
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
1209 (A64280)
1209 (A64280)
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
