Snow 59" front mount snow blower speed
/ 59" front mount snow blower speed #1
Forrest1357
Marengo, IL.
John Deere 3720
I have a 59" JD snow blower on my 3720 and it works perfect with one exception. I can adjust it to go up slow or fast but down is another story. It is full blast to the ground. Does anyone have any suggestions?
/ 59" front mount snow blower speed #2
I have 4410 and if I push the lever all the way into the float position the snow blower lowers quite gently to the ground.
/ 59" front mount snow blower speed #3
I have a 3720 and a 59 snow blower attached with front quick hitch A-frame mount. It has a fluid control valve at the front up/down cylinder for adjusting the drop rate. I adjusted the valve when new about 7 yrs ago and have never had to change it. Are the hydraulic hoses connected correctly?
/ 59" front mount snow blower speed #4
Joy stick control? What do you adjust for slowing down the "up" speed? Push forward on the joy stick to lower the snow blower, or pull back on the stick?
/ 59" front mount snow blower speed #5
I wonder if there is supposed to be a orifice in the down hose that is missing. Just a thought.
/ 59" front mount snow blower speed #6
I'm thinking the hoses may be reversed at the quick connects ?
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Goosen Bale Chopper Hay Blower (A61166)
Goosen Bale...
