Snow 59" front mount snow blower speed
/ 59" front mount snow blower speed #1
Forrest1357
Marengo, IL.
John Deere 3720
I have a 59" JD snow blower on my 3720 and it works perfect with one exception. I can adjust it to go up slow or fast but down is another story. It is full blast to the ground. Does anyone have any suggestions?
/ 59" front mount snow blower speed #2
I have 4410 and if I push the lever all the way into the float position the snow blower lowers quite gently to the ground.
/ 59" front mount snow blower speed #3
I have a 3720 and a 59 snow blower attached with front quick hitch A-frame mount. It has a fluid control valve at the front up/down cylinder for adjusting the drop rate. I adjusted the valve when new about 7 yrs ago and have never had to change it. Are the hydraulic hoses connected correctly?
/ 59" front mount snow blower speed #4
Joy stick control? What do you adjust for slowing down the "up" speed? Push forward on the joy stick to lower the snow blower, or pull back on the stick?
/ 59" front mount snow blower speed #5
I wonder if there is supposed to be a orifice in the down hose that is missing. Just a thought.
/ 59" front mount snow blower speed #6
I'm thinking the hoses may be reversed at the quick connects ?
2013 HPX Gator 4x4 Gas Utility Cart (A61567)
2013 HPX Gator 4x4...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
GMC V6 MOTOR (A62131)
80003CFL (A61568)
80003CFL (A61568)
2024 BOBCAT T66 R-SERIES SKID STEER (A62129)
2024 BOBCAT T66...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
