Hay equipment questions
/ Hay equipment questions #1
hotchkiss
Gold Member
Ohio
JD 6330, JD 5055e, Ford 4000,
1. Which inline small bail bailer do you like best and why?
2. Which accumulator and grapple go you like best.
I will be bailing 25 acres of alfalfa.
/ Hay equipment questions #2
We use a kuhn accumulator and bale grabber. It's the 10 bale with the end bales turned. It made things easier but it certainly took some getting used to. Make sure you have access to Machine friendly storage or help to unload the hay. Stacking squarely (pardon the pun) is critical to getting the hay to trailer and be able to regrab the hay.
/ Hay equipment questions #3
I make lots of sm. square bales and we've run NH balers since the 1975 and the 575 models since 2006. The NH 575 is a good solid dependable baler that eats hay. Hesston makes a good baler along with JD. I guess it depends on what you have close by for a dealer. Only draw back I have with the Hesston inline is if you run older smaller tractors and make big swaths, sometimes it can catch up under the hitch. So one has to watch for that issue depending on tractor. I use a NH bale wagon to pick the bales though so have no info to share on accumulators.
Hay is delivered by the stack with stack retriever truck.
Thanks. It appears as though you tried to send some photos, but they did not transmit.
Arrow Quip Head Holder (A64047)
Arrow Quip Head...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
CRAFTSMAN 20 GALLON ELECT. AIR COMRPRESSOR (A62131)
CRAFTSMAN 20...
2008 Toyota Rav4 SUV (A61569)
2008 Toyota Rav4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
