Grid-tied solar
/ Grid-tied solar
Interesting Chinese perspective on solar energy.
I think the "... you need six square miles of our solar module to generate electricity to power an electric car." is a typo. I'm guessing six square meters.
"What is interesting with this third [energy] revolution is that it’s not about a competition for resources; it’s a competition of core technologies."
http://www.nytimes.com/2014/12/01/b...ing-group-on-the-energy-source.html?ref=earth
/ Grid-tied solar
The November, 2014 results.
Just above the model by one-half of a sunny day, like October. Way below the two previous Novembers. We did have some gloomy weather most of the month.
Month--NREL Model (AC kWh)--2012 Actual---2013 Actual---2104 Actual
Jan.----388----------------------NA--------------440-------------360
Feb.----412----------------------NA--------------375-------------446
Mar.----509----------------------NA--------------462-------------577
Apr.----374----------------------NA--------------487-------------525
May----353----------------------NA--------------375-------------361
Jun.----308----------------------NA--------------379-------------390
Jul.-----341----------------------NA--------------377-------------395
Aug.----383----------------------461-------------470------------453
Sep.----394----------------------481-------------476------------489
Oct.----369----------------------378-------------453-------------380
Nov.----283----------------------400-------------414------------295
Dec.----331----------------------297-------------278
/ Grid-tied solar #646
Morning All and Dave too - thought just to post here rather than start a new thread since your advise and direction Dave led me to Revision Energy in the first place.
Well, 2 installers from Revision Energy arrived yesterday and got all the rails installed, and Solaredge inverter installed in the third garage bay area and the conduit runs in.
They installed a monitoring meter to the right of the inverter which shows total production - not really necessary, but this is their "standard practice" also I understand this can be used to track SREC but currently we don't have a purchase program in NH..
There will be no visible wiring or conduit - its all above the dropped ceiling and they came through the roof with a junction box installed with flashing under the shingles so it will be hidden by the panels. My office 16x42' is in the upstairs area - we have knee walls so all the wiring runs are inside.
Overall great attention to detail with a neat and professional installation. No, I didn't get the lowest price at $3.65 per watt but a quality installation - they hit each rafter with the 3" SST lag bolts and sealant in and around the mounting and its all level and square..
They will finish on Monday with the panel installation 24 LG300W Neon with SE Optimizers for a 7.2KW system. More pics will follow on completion.
/ Grid-tied solar
Thanks for the update Carl. Looking good and good to hear Revision is still doing respectable work--and glad your target date will be met. The monitoring meter is something I'm not familiar with.
Does/will your inverter keep total production history? Maybe that's something to do with the meter. Ours displays AC kWh produced since install and AC kWh for the current day's production. We didn't opt for the network interface that would allow storing hourly and daily production history. I have a feel now for how many kWhs should be produced given the amount of sunshine for the season; I walk past the inverter often during the day. That's how I monitor the system for potential problems on a daily basis, haven't had any yet.
I ended up with both In (from the grid) and Out (to the grid) meters from Central Maine Power for our net metering. I pay the monthly net difference between those two meters, or bank kWh credits if the Out exceeds the In. They are 'smart' meters with transmitters but for whatever reason the CMP truck has been coming up the drive to read them each month again lately. The meters may be 'smarter' than CMP? :laughing:
/ Grid-tied solar #648
Dumb question.
I know you guys are tied to the grid, so if the grid goes down in the daytime, can you run things if you disconnect at the pole?
/ Grid-tied solar
Dumb question.
No. Not for a standard grid-tied system. They shut down when no grid power is sensed. That's for two reasons: lineman safety, and they get their 60 cycle clocking from the grid power usually since they need to sync to that to be combined with grid power in your service panel.
There are a few hybrid grid-tied systems that will run and provide limited power without the grid being up though.
/ Grid-tied solar #650
Hi Dave,
The SolarEdge Inverter along with the per panel optimizers allow me to monitor each panel output also minimize shading issues, with nearly any report hourly, daily monthly available. It will be connected to the network and as soon as we are generating power I will have a web link to view the production.
PSNH, our power co will be installing a new meter for the net metering as well once the system is operational.
/ Grid-tied solar #651
Maybe one of you will know. Is there a way to use the solar panels with a small inverter type generator like maybe a Honda 2000i. To supply power during an outage (thinking days or weeks not hours) for things like heating while your away during the day. Then after dark switch to a larger genset maybe even whole house during the night when power usage is greatest. Of course this would need lockouts and proper switch gears. But is it possible?
/ Grid-tied solar #652
Farmer,
No its typically not possible to run the generator and the PV system during an outage. I say "typically" because there is probably a way to do this but you would need a fair amount of switching to accomplish this to code. The costs would outweigh the savings I think of a standard generator system
Likely others will chime in on this in more detail.
/ Grid-tied solar #653
Farmer,
I have thought of that and as long as its an inverter (so it can throttle down) and the solar is tied into the main panel, the solar shouldn't know the difference between the grid and a generator.
Aaron Z
/ Grid-tied solar #654
Aaron,
Solar output is variable - clouds and rainy days and much of the time when we lose power its bad weather - snow or hurricanes, etc.
I agree with you that the solar should not care the source of power, but with 2K generator and variable output of solar would only support a small load - a few lights and maybe a furnace or fridge. In order to get more level output capacity a battery bank on the solar would be one way - there may be others.
This is more like an "off grid" or hybrid type system..
/ Grid-tied solar #655
Aaron,
Agreed. My thought is that if you have an inverter (generator or battery powered) sized to carry your load the solar could take the load off of the generator and let it idle down saving gas or battery for when its dark out.
Aaron Z
/ Grid-tied solar #656
Aaron, Solar output is variable - clouds and rainy days and much of the time when we lose power its bad weather - snow or hurricanes, etc. I agree with you that the solar should not care the source of power, but with 2K generator and variable output of solar would only support a small load - a few lights and maybe a furnace or fridge. In order to get more level output capacity a battery bank on the solar would be one way - there may be others. This is more like an "off grid" or hybrid type system..
Yes solar is variable but if you will watch around bad storms (atleast in my area) the few days after the storm. Being ice or tornados or snow is usually sunny. Bad Storms don't come through and then leave clouds around for days, they use up what ever energy is in the atmosphere and then leave clear skies. My thoughts were about low usage times. Running a gas or wood heaters blower. A fridge and freezer when needed.
Maybe it come down to another post. Not as much about is it possible but is it feasible.
/ Grid-tied solar #657
I really am enjoying this thread, it has got me to thinking.
Hmm....
/ Grid-tied solar
TnAndy is a great resource for this discussion. If I understand his system, he is set up to switch his grid-tied system output into his off-grid system when the power is off. The off-grid system has a battery bank and that is very useful for electrical loads.
The batteries do what the grid does in a grid-tied system. They fill on-demand calls for power that exceed the solar panels current (in time) output, and they are somewhere to store power when the load is below the panels' outputs, and of course supply 100% of the power at night.
On a partly cloudy day the output of a solar system will be all over the place from low to maximum. That brownout condition is not what AC electric motors will function well on. You could use variable speed DC motors and allow them to run at whatever voltage is available directly from the panels, but that has drawbacks too.
I don't know how well inverter generators handle having power applied to their output terminals. That would be the situation if the generator and a grid-tied system were combined in a service panel. They would each have their own dedicated circuit breaker that they feed the panel through. Generators are designed to be power sources, not sinks. Whether that is not an issue with inverter gens, I don't know.
Assuming the generator is going to work that way, it would supply the clocking for 60 cycles that the grid-tied system would sync to. The loads on the panel would draw from the combined generator and solar inverter output with the generator filling the grid function.
Where trouble would start is if the load exceeds that combined capacity; there is no grid or battery bank to make up the difference. Let's say the load is 4 kW, the generator is a 2 kW unit, and the solar system has a 4 kW capacity. You won't always get the 2 kW needed from the solar system to meet the 4 kW load unless it is a cloudless day. It could easily vary from .5 kW to 4 kW. In any case at dawn and dusk you won't get the 2 kW either. If motors are starting and stopping, the start-up loads need to be met too.
The price differential between a 2 kW and 5 kW generator (needed for a 4 kW load) is a lot less than the cost of the solar system. Plus it works in the dark of night, during storms, and on cloudy days. I don't see much advantage in trying to use a grid-tied solar system as a generator fuel saver or capacity extender/booster.
You can open the main service disconnect and take care of the utility line backfeed safety issue. A manual breaker lock-out meets code, but lock-outs are not designed for two backfeed breakers IIRC. There is likely a reasonable solution for that problem.
/ Grid-tied solar #659
Not workable as a capacity extender IMO due to the variable output, just as a gas saver. My thought is that the fuel savings would be a bonus of having a grid tie system.
On the "backfeeding the inverter issue" I suspect that as long as your total load is low enough that the genset can handle it, the genset will just see a reduced load when the solar panels are producing power.
Most grid tie systems (from what I understand) will not "fire" the inverter and supply power until they see 120VAC @ 60hz, thus only one lockout is needed.
Aaron Z
/ Grid-tied solar #660
A question concerning home solar power: A bit off thread but thought someone here might know the answer.
This is about OFF grid solar and not an invitation to debate ... please.
Is off-grid solar susceptible to EMP? If so, is it only specific components at risk?
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
