Mid-size Johndeere
/ Mid-size Johndeere #1
Tatefarms
Rockwall,Texas
John Deere 7410 John Deere 5101 John Deere 4310 Ford 601 workmaster genie 5519 telehandler
I need some advice on model numbers. I need a four-wheel-drive loader tractor as small and light weight as possible , Cab or open station with the loader capable of picking up large round bales (2500#) and loading the top deck of an 18 wheeler. Right now we have a 7410, 6410,5101e all to big and 4310 to small . We had a 5210 and it would barely do all those jobs. So something similar or bigger will work.
/ Mid-size Johndeere #2
I'm a little stumped.... I would recommend something along the lines of a big 5e series deere but you already own one. Anything less doesn't seem to me that it would be well suited to loading 2500lb bales. Curious to hear others thoughts...
/ Mid-size Johndeere #3
It seems obvious to me that if a 50 some HP tractor would barely do what you need and 100 HP tractor with a larger frame was too big that something in the middle would work? :confused:
/ Mid-size Johndeere #4
You already have a 7410. (with a loader?) Strip it of all extra weight ie no fluid in the tires. Use a grapple on the front and load two bales at a time. Put a fork on the rear and use a bale as a counter weight.
/ Mid-size Johndeere #5
I've never seen a 2500 lb round bale. What are they? Is it haylage?
You're talking about lifting them pretty high too. You might have unrealistic expectations. It seems to me that you already have the proper machine. Can you explain why the 5E is too big for a 2500 lb bale?
/ Mid-size Johndeere #6
What? Read what he said again.
/ Mid-size Johndeere #7
Check out the 5e line. 45-75 hp with the h240 loader. In the middle between your 4 series and larger e series
Brett
/ Mid-size Johndeere #8
Probably THE most confusing post I have seen . What are you trying to do ? Low clearance at the building ? 2500# bale will take a 10,000# tractor .And what is the top deck ?
/ Mid-size Johndeere #9
Easy If you load 2500 lb bales two layers high on a semi with anything less than roughly that size of a tractor your stupid. Just my opinion. If you need small then buy a similar one without a cab. I'm assuming he wants to trailer the tractor hence less weight ie no fluid and a bale spear. If you need small to get into tight places than use the telehandler or make smaller bales.
/ Mid-size Johndeere #10
I would think the 6410 is the smallest I would want for that ? Or make smaller more suitable bales and use a small tractor .
/ Mid-size Johndeere #11
... I'm assuming he wants to trailer the tractor hence less weight ie no fluid and a bale spear. If you need small to get into tight places than use the telehandler or make smaller bales.
He said too big, didn't mention too heavy. That is where you lost me.
/ Mid-size Johndeere #12
Telehandler They are using them around here to load round cotton modules in the field.
GTH
/ Mid-size Johndeere #13
No brand war intended.
JD tractors tend to be heavy for their HP. So if lighter is paramount you'd switch colors.
But then you'd be trying to load 2500lb bales with a light chassis and you'd add ballast to compensate.
Thus, I can't see the problem with the 5E you already have.
But then, none of us are there. You are.
So, seeing your current selection of tractors and the conditions you've offered, I don't think JD makes a tractor to fit your needs.
/ Mid-size Johndeere #14
GTH
I see that the OP has a telehandler listed in his signature. He seem's pretty well equipped already.
/ Mid-size Johndeere #15
Compact track loader. John Deere 333E or equal. Should be able to lift to 100 inches.
If these are large, square bales start by stacking one bale on the trailer. Then stack two bales high on the ground and lift from the bottom bale to the level of the bales already loaded on the trailer - bales are then stacked 3-high.
/ Mid-size Johndeere #16
There ya go! Didn't think of a track loader! I like it! But, the OP might have to swap out the 7000 or 6000 series machines...
Kidding!
Neighbor uses his Bobcat 320 CTL to load small squares with a 10-bale grapple. Fast.. Fast...fast! And minimal field damage.
AKfish
Right. I'm asking for model numbers.
I've never seen a 2500 lb round bale. What are they? Is it haylage? You're talking about lifting them pretty high too. You might have unrealistic expectations. It seems to me that you already have the proper machine. Can you explain why the 5E is too big for a 2500 lb bale?
Good grass through a vermeer 605 at 72 inches.
Okay I'll try to explain it better for you guys. I Need a mid-size tractor. Similar to the 5210. Trying to figure out what other model numbers were for that same frame size tractor. I need a tractor that I can use in my indoor arena that has hydraulics on the rear for my drag and my hydraulic dump trailer. Would like it to be 8000# or less. I need this tractor when all of my other tractors are busy doing other jobs. The bales through our 605 vermeer average 2200#. We have a 5519 genie with a double bale grapple we unload trucks and stack the barn with. This will not be my #1 hay handling tractor but want the same size and abilities as the 5210 in a newer model.
/ Mid-size Johndeere #20
Well, that narrows things down real good! That puts you right back in the 5000 series machines. Are you lookin' for an open station tractor or a cab? If weight is a concern, I'd stay with the E tractors. So, if memory serves the 5210 is around 55Hp. So, that would be either a 5055D (2WD) or a 5055E (4WD).
The D and E models are a bit lighter frame weight than the M tractors but you could stay with an open station and keep the weight down. The M's have a beefier transaxle housing, more transmission options, higher output hydraulics and heavier duty loader options. But, the bottom Hp level starts at 75Hp.
Best of luck. Lookin' forward to see what you finally decide on.
AKfish
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
2022 John Deere Z930M (A57148)
2022 John Deere...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
